depends on the size of the wire being run back and the size of the amps. I'd run all seperate wires
Im setting up my car PC + inverter in the trunk, later on i want to Install 1 or 2 amps for the speakers, should every device get there own power line? or can I split one?
Pontiac Grand Am
building CarPC useing BookPC and Lilliput 7 inch TS.
'98 Explorer Sport
80% done
i got an 8 gauge for the inverter. im not gonna run very powerful amps, like a 100x4 and like a 200x2.
Pontiac Grand Am
if it was me:
-buy a 4 gauge (to go from battery to trunk)
-get a distribution blaock (http://cgi.ebay.com/ws/eBayISAPI.dll...category=50550
-have the 4 gauge wire go to the distro block, then you can have 3 8 gauge outputs using the wire you already have, one to your inverter, one to your carpc, and one to an amp
92 Taurus SHO - Daily driver - Epia M10000 80GB 512mb 7" touchscreen, Opus PSU etc
93 Black SHO - 30mpg cruiser
90 Silver SHO - 419whp fun/project car, CarPC to come (for tuning)
can i use a big cap to support the whole system?
Pontiac Grand Am
The short answer is the more draw, the bigger cap you need... a lot of discussion on this topic you can read yourself.
If you are that worried about it, then off the beforementioned distribution block, put a cap for each amp and your computer.
If your in the states, walmart carries Scosch now at good prices. The big kit comes with 4 and 8 gauge wires, a distro block, and inline fuse. You probably won't need a cap for your system. But a tank circuit would keep your PC from rebooting when cranking ect.
For once I agree with guitar
i got the walmart dual amp kit, pretty awsome deal.
Pontiac Grand Am
