Results 1 to 8 of 8
Thread: An Idea for you electronics genius's
    Oct 2003
    I know very little about electronics, but after looking at some of the posts here about power supplies and shutdown controllers, I think somebody could make some good cash by making a device that implements both the shutdown controller and power supply into 1 unit. It would be great for saving space in a case hopefully and would give some newbies an easier way of hooking it all up.
    Just a thought that somebody here that has an electronics background may want to take a bit further.
    FLAC shakes's Avatar
    Oct 2003
    Atlanta GA
    it's called the opus ... they have a few different versions, and based on what they're charging i'd assume they're making some good money
    Maximum Bitrate osirisdon's Avatar
    Feb 2003
    South Florida
    Oct 2003
    OHHHH damn..... I didn't even realize that the opus had a shutdown controller in it. Well my bad, I "figured" that the opus was just an overpriced power supply, but after reading into it I feel like a complete moron!! My bad!!
    Newbie alphonsus's Avatar
    Oct 2003
    Well it wouldn't hurt if someone else could build one too. That would hopefully bring the price down. $150 is a bit much imo.
    Oct 2003
    Atlanta GA
    minibox bill have a shutdown controller out soon. So you will probably be able to get the whole solution from them for under $100. it'll be two boards tho.
    and the opus also provides voltage regulation, which is where some of the cost comes from. With the minibox supplies you need to regulate your 12v before giving it to the ps
    Nov 2003
    The Opus has 150W right?
    is that enough to supply a PC and a TFT display?
    Any power supply in a desktop pc hast at least 300W!
    Oct 2003
    Atlanta GA
    opus has a 150w model yes. they also have smaller versions.
    is it enough? depends on what you plan to power off of it. most desktops have at least 300w because they are capable of powering 4+ 12v IDE devices, 5+ expansion cards, and any nummber of USB devices.
    even then most PCs don't consume much over 200w.
    that's why most peopl erun laptop drives. low power consumption and very rugged.
    the TFT takes next to no power. read the spec for your screen ... it will tell you the power needs.
