Results 1 to 4 of 4
Thread: My experience with Ituner ITPS so far...
    Dec 2002
    Chico, Ca
    I picked up the ITPS from Ituner's shop today and I have put it into my car tonight. It does exactly what I want it to. Turn on the ignition and it turns on the motherboard. Turn off the ignition and the system turns off. I just made sure that windows was set to hibernate when the signal is sent to shutdown. I haven't had much more time then to see if it works. In the end it's not vapor ware.
    Newbie gtrfvb's Avatar
    Nov 2003
    Central New York
    Cool, nice to know it works. Could you take pics of it connected? Id like get a rough size so i can start planing a case. Also, does it have mounting holes, or does it not need them?
    Dec 2002
    Chico, Ca
    I can't post any pics for size because the thing is now buried in my dash. I believe it's about 4-5 inches in length and mabye at the most 3/4's of an inch wide. There are two screw holes located about half an inch back from the tips of the board. I used to standoff screws from a motherboard and screwed it into my case. Avoid grounding the metal heatsink because it won't work if you do that.
    Aug 2003
    Seattle, WA
    Quote Originally Posted by adamis
    Uh, aren't most heatsinks designed to be ground or grounded anyway?
    Pv
