Results 1 to 5 of 5
Thread: Problem testing VIA EPIA w/standard atx power supply
    Nov 2003
    Pittsburgh
    I'm testing out an EPIA mini-ITX board using a standard ATX P4 power supply. The kind that plugs into the wall. I'm testing out some circuitry to run from the parallel port. In any event, I plugged in the atx connector and of course there is no power. I need some kind of switch. One of the cables coming out of the power supply has 4 female pin holders on the end connected to 2 black wires and 2 yellow wires. I'm thinking that some kind of switch is supposed to attach here. Is there a way I can jump these to turn on the power supply?
    I realize this is really basic but I'm stuck.
    Aug 2003
    Lancaster, PA
    NO!!! That's the aux connector for P4s. What you need is a switch for the motherboard, a monetary switch like this link
    Nov 2003
    Pittsburgh
    Figured it out
    Thanks for the response. I must be on drugs to have not figured it out sooner. I just took a screwdriver and jumpered the power switch jumper on the motherboard (one of those jumpers that you connect to the case wires). Anyway, she powered up as smooth as can be
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    Quote Originally Posted by khufumen
    I started mine like that for a month...then I found out that it will auto start just from pressing a key on the keyboard...wooo fancy.
    Aug 2003
    Lancaster, PA
    I use the screw driver method too, if I can remember which pins I'm supposed to short
