Results 1 to 2 of 2
Thread: Remote Wire Amps
    Dec 2002
    San Diego
    Remote Wire Delay (Prevent Speaker Thumping)
    Okay. Here's the kink I'm trying to work out. I did a search about 'thumping/banging speakers' which pretty much is the computer volume instantaneously turning on and and off upon carputer powerup and this causes a really loud and I'm sure a bad sound for the speakers. I'm trying to solve this problem. Basically my two amps turn on through a remote 12v ignition wire. To stop the thumping when the puter turns on, I can put a capacitor inline to cause a simple <1sec time delay. and this will provide it enough time so that you don't hear that thump upon startup. The solution I thought up for shutdown is to utilize my mobo power switch but splice in the remote wire so that when I push the button, my puter will hibernate (I don't have a shutdown controller) and also it will send a 12v source to shut the amps down. The theory behind this is that since it takes ~10sec to hibertate the puter, the amps will already be off and thus no thumping upon shutoff. The problem I'm having is implementing both into a circuit, because once you put a switch in, you have to use it upon starting up the car; in other words, I need to hold the switch down to provide a 12v source when the ignition is on, to cause the delay. I want to make it so that things are more automatic. Any suggestions? I hope I explained it rather efficiently. Please ask me to clarify certain parts if needed.
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    Did you double post this?
    Remote Wire (Prevent Speaker Thump)
    That is a Bozo nozo.
