Results 1 to 10 of 14
Thread: Question about the opus dc/dc converter...
    Nov 2003
    Annapolis Maryland
    I know this is a newb question but, before i go buying one of these things i want to know how does it hook up to your car? Does it plug in to where the head unit plugs into (the power cable) I tried looking everywhere and couldn't find any info on this. Any help would be great. Thanks!
    Newbie Dr Frag's Avatar
    Nov 2003
    Southern California
    Normally what one would do is run seperate wires directly from the battery to the PSU.
    DF
    Nov 2003
    Annapolis Maryland
    Quote Originally Posted by Dr Frag
    DF
    Directly from the battery? I would have never thought that. How would it shut off if its directly hooked to the battery? I guess i would have to do it manualy.
    Maximum Bitrate Naamanf's Avatar
    Sep 2003
    Colorado
    Quote Originally Posted by Animepix
    You all have a remote line that you use for turning it off and on. You hook it up to your head units amp turnon or ignition. It will turn on the computer when it gets 12v on the remote line, and then tell the computer to shutdown/standby when the 12v is remoted. It also can be timed from 20min to and hour.
    2007 Tahoe
    Opus with iBase 896 and Pentium M 735 Transflective Xenarc Alpine DVA-9861, PXA-H900, Sinfoni 45X2 (2) 90x2, Genesis Dual Mono, JL 1000/1 (2), Focal Be tweeters, ScanSpeak Revelator Mids, Dynaudio MW170, Dayton 12" Ref.
    My Install
    Nov 2003
    Las Vegas/Henderson, NV
    Does the ATX 150 DC-DC converter work with a ITX/Mini-ITX board?
    Sep 2003
    Colorado
    Quote Originally Posted by Almost a Ghost
    It sure does.
    2007 Tahoe
    My Install
    Nov 2003
    Annapolis Maryland
    Quote Originally Posted by Naamanf
    OOOoohhh, i think i know what your talking about. You mean that blue "power antenna" wire thing. I didn't know that could hook up to the opus. It all makes sence now. Thanks!!! You don't know how much that means to me.
    Maximum Bitrate SjLucky's Avatar
    Jul 2003
    Hattiesburg, Mississippi
    No no no no not the power antenna wire
    the remote turn-on wire
    The power antenna makes your antenna go up and down if you have a power antenna
    Quote Originally Posted by menudude View Post
    thank you all for your help minus the useless post by sjlucky...
    Nov 2003
    Southern California
    Quote Originally Posted by SjLucky
    Ain't that what a power antenna wire is, a remote turn-on wire for the antenna? Those were always the same thing back when I was building car stereos. It's just +12v out when the radio is turned on. Ain't it???
    DF
    Jul 2003
    Mmm now that I think about it it would keep the 12v cause it doesnt have the antenna motor to tell it to shut off...
    Hell its not like I jack try it find out educate us all..
