Results 1 to 3 of 3
Thread: New psu for under 100. 11 left.
    Aug 2003
    An alternative to whats out there. Id buy one but i need more power than this. Not sure how long I can wait to get my opus one. But anyway there ya go.
    FLAC Mastero's Avatar
    Aug 2001
    Time to open an umbrella
    Maximum Bitrate PTCruiser's Avatar
    Oct 2002
    The LM-1084 is a low dropout voltage 1C that provides regulation for the ATX PW120/120A DC DC converters or any other attached device. In case 12v regulation is not needed the LM-1084 can be bypassed by applying a solder bump. I will show you where to apply a simple solder bump if you need to bypass the regulator
    => this solution will work only with engine on...or a battery in a good shape
    Dropout Voltage for the LM-1084 =1.30 Volt
    Vin must be >13.3V to get Vout regulated. (low drop out regulator...)
    this will not work when your start your engine (with a regular battery)
    They bypass this:
    Ignition = ON: ITPS waits for 3 - 4 seconds then turns on the main 12v rail...
    I wonder how this can work engine turn Off (in my car I got engine on ~14V, Off ~12.5 V)
    This come PSU from mini-box
    Epia M9000, lili 7" vga&touch & 2xTM-7002S compo, camera with reversed image, 2.5" 60 GB, 256Mb DDR, Opus 90W, GPS usb... AND MEDIACRUISER of course!
