Results 1 to 8 of 8
Thread: Opus Install Question
    Jan 2003
    hey what's up, i hooked up the opus to my computer in the car and it works fine when i turn it to the acc position but when i start the car the screen goes blank, i think it is restarting the computer when i start it. Did I wire this incorrectly? Thank You
    Jason
    Jul 2002
    Boston, MA
    Quote Originally Posted by IIJasonII
    Jason
    Be sure the main power wire is attached either directly to the battery, or the less desirable spot, a spot on the fuse box that doesn't disconnect when you crank the engine...
    -Mario
    Jan 2003
    so when you crank the engine, the psu gets the power from the constant 12V (the yellow wire)?
    Variable Bitrate inniss777's Avatar
    Oct 2003
    SOCAL
    In reality the computer will always have power because the red power wire will connect to your battery and your battery is always on. The yellow is just a signal to tell the computer to turn on or standby/ hibernate what ever you choose in the settings.
    Opus case. MB 899 core duo 2.0ghz
    Dual vga out, 400 gb hard drive, Centrefuse front end
    zapco 1000.4 for zapco 6.5 componets
    zapco 1100.1 for 2 13" W6.
    Sep 2002
    Worcester, MA
    Look here. Thats the 90watt opus. The connector on the bottom is where you connect up the battery. Like inniss said, the red goes to positive, black to ground. The yellow is NOT however the remote. That is the wire that hooks up to the ignition wire so it turns on with the rest of the car. The top connector (not available on the non-remote trigger versions) is the remote trigger 'port'. It comes with another smaller wire harness with 3 wires. Two of them are useless, one is the remote trigger wire, which you would hook directly up to the remote trigger input on the amp. I have this set up right now in my car and it works flawlessly.
    hope that helps, there was a lot of confusion back when it was released as to which wire was the remote trigger, becuase some of the wireharnesses were not included.
    Variable Bitrate telekineticfool's Avatar
    Mar 2003
    AZ
    what's your screen wired to?
    MP3 MR2 (click here for details)
    Hardware: EPIA M10000, 512Meg Ram, 5.6"TFT, Opus 150watt DC-DC PSU
    Software: Windows 2000, Media Engine 2.0
    Jan 2003
    screen is wired to battery with inline fuse.
    Oct 2003
    SOCAL
    Quote Originally Posted by naevity
    The yellow wire could be wired to the ignition or it could be wired to the remote wire from your radio so that when ever you turn on your radio the computer turns on.
