you don't need 12V regulated to produce 5V regulated...
How much amperage do you need?
With low amperage use a linear low drop out.
With higher amperage use a DC-DC 12V->5V
Guess I might be blasted for not searching, but the search engine here is kinda picky and I wasn't having any luck.
So I have this 12 volt regulated power of 70watts. Its a dc to dc convertor from mini-itx.com. I was thinking about mounting this in the front of the car and having it power any misc perhipials I plan to mount up there, while in the rear of the car mounting the opus 150watts. So I have this slimline cd/dvd in a case which outputs to firewire, and it is requesting 5 volt dc. I bet theres an easy way to get 5 volts from a 12 volt supply, but I don't know where to look other then here.
If you have any good reading, please point me to it.
Thanks,
-Jason
Epia M9000, lili 7" vga&touch & 2xTM-7002S compo, camera with reversed image, 2.5" 60 GB, 256Mb DDR, Opus 90W, GPS usb... AND MEDIACRUISER of course!
PT6625: http://focus.ti.com/docs/prod/folders/print/pt6625.html
Small, efficient, easy to use. It's what I use to power my computer (along with a PT5071 for the 12V).
Rob
Why not run the 5v from your Opus in the trunk.
I'm now using the atx 5v lead to power the external cdrom and its working like a champ
Thanks,
-Jason
Here is how to properly wire a voltage regulator using the LM7805 voltage regulator...Its a step by step tutorial...Voltage Regulator Tutorial
-afreeland
