Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: can anyone design a pulse circuit......
  1. #11
    Raw Wave
    Jun 2003
    Yup the guy called beakmyn who posted the link
  2. #12
    Variable Bitrate rgardjr's Avatar
    Oct 2003
    I bought one of these cheap off ebay DEI 528T Pulse Timer:
    http://cgi.ebay.com/ws/eBayISAPI.dll...ory=14934&rd=1
    Adjustable pulse length. I paid $9.90 with shipping.
  3. #13
    Maximum Bitrate none's Avatar
    Sep 2003
    Jamez,
    I made a circuit almost identical to yours (except with a diode, similar to Mike Carr's design,) and it has a problem with the cap discharging and sending a second pulse a minute or two later. Let me know if yours works. I even spoke to Mike Carr about it and he admitted that he had no idea, he just copied the circuit from someone else himself.
    What is the blue thing above the resistor in your design?
    SuperSonic,
    Your controller doesn't send a second pulse and shut down the computer a minute or two after starting? Do you mind if I ask the exact specs of the parts you used? My circuit is only half that design since I only need the startup pulse, but I think it should work anyway.
    Thanks.
  4. #14
    May 2003
    UK
    its just a tes probe ( its a screenshot from a circuit simulator)
    www.digital-car.co.uk - The UK CarPC Forum
  5. #15
    Sep 2003
    BTW I'm now building a circuit based on a 555 chip.
  6. #16
    Newbie SuperSonic's Avatar
    Feb 2000
    Belgium
    none,
    I have no second pulse on the circuit as far as I could test.
    Parts are :
    -3x Scrack T7NS5D1-12 10A@28VDC Relays
    -2x 1000F 25V El. Capacitors
    -standard diodes and resistors
  7. #17
    Sep 2003
    Update: the unwanted pulse was coming from the Mucha controller, not my startup circuit. I didn't have the time to futz with it, so I replaced the whole mess with an ITPS (modified to bypass the regulator) and everything is working great now. I really wanted the flexibility that the Mucha contoller offered, but I've had nothing but problems with it.
  8. #18
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    How about a circuit that pulses once when a switch is closed, and then pulses twice when a switch is opened? It could operate on either 12V or 5V.
    The reason I ask is because I think the Lilliput (in pieces at the moment) cycles through the VGA, Composite 1, and Composite 2 video inputs with each input switch closure. This circuit would make it possible to implement automatically switching to a rear camera input when reverse gear is engaged, and back to VGA when it is disengaged.
    Fabricator
  1. tank circuit - what output do I need?
    By maxcosity in forum Power Supplies
    Last Post: 06-03-2003, 04:00 PM
  2. Trying to build a circuit or 2... HELP!
    By ddt in forum General Hardware Discussion
    Last Post: 03-01-2003, 09:34 PM
  3. Special audio preamp circuit
    By claylong in forum General Hardware Discussion
    Last Post: 01-14-2003, 05:19 PM
  4. Circuit design software
    By phil.45 in forum Software & Software Development
    Last Post: 09-20-2002, 10:23 AM
  5. Need help on power on pulse
    By Jothen in forum Power Supplies
    Last Post: 06-04-2002, 08:28 AM
