Results 1 to 10 of 18
Thread: can anyone design a pulse circuit......
    May 2003
    UK
    can anyone think of a circuit that will - when receiving 12v, switch a transistor on for about a second and then switch off ? ( can this be done simply with a capacitor or something? )
    James
    www.digital-car.co.uk - The UK CarPC Forum
    Newbie SuperSonic's Avatar
    Feb 2000
    Belgium
    This should serve you right.
    I made it myself too it is fully functional and a breeze do make. Not my design!
    May 2003
    UK
    thanks, but I allready have a shutdown controller, i just want a circuit that when powered up with 12v closes a transistor for about a second then off again - according to the simulator the below image will work - but I would have thought it could be done simpler with a few caps and resistors?
    James
    Apr 2001
    Portland OR
    Quote Originally Posted by Jamez_Warner
    James
    Just put the 10uf cap in the holes. round is minus and square is plus.
    -Jeff
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
    May 2003
    UK
    i have ( works ), but of course we have hit the problem of it malfunctioning when I turn computer back on before timer has expired
    James
    Nov 2003
    This site should get you going.
    http://www.the12volt.com/relays/page5.asp
    Raw Wave
    Jun 2003
    Wow...didnt know someone can even think of using 5 relays just to do something very simple. He must have lots of spare relays.
    Its an interesting page though
    May 2003
    UK
    thanks ricky that's perfect - I have formed the following diagram:
    this means with jeff's shutdown controller - it will give a power on pulse everytime the pc recieves power so you can't lose sync by turning key again while the timer to shutdown is still counting... ( ppl with jeff's controller will understand )
    Raw Wave
    Jun 2003
    Jamez_Warner
    I think you supposed to thanks someone else
    May 2003
    UK
    lol
  1. tank circuit - what output do I need?
    By maxcosity in forum Power Supplies
    Last Post: 06-03-2003, 05:00 PM
  2. Trying to build a circuit or 2... HELP!
    By ddt in forum General Hardware Discussion
    Last Post: 03-01-2003, 10:34 PM
  3. Special audio preamp circuit
    By claylong in forum General Hardware Discussion
    Last Post: 01-14-2003, 06:19 PM
  4. Circuit design software
    By phil.45 in forum Software & Software Development
    Last Post: 09-20-2002, 11:23 AM
  5. Need help on power on pulse
    By Jothen in forum Power Supplies
    Last Post: 06-04-2002, 09:28 AM
