Results 1 to 6 of 6
Thread: Idea for a shutdown controler
    Maximum Bitrate owenjh's Avatar
    Nov 2003
    Lightbulb Idea for a shutdown controler
    Excuse the colors it looked better till paint saved it in 256 color bitmap It was not my fault I did not read the box the computer did it I tell you.
    Not sure if this would work or not, let me know what you think, it would be nice if it did work wouldn't it :-D the only thing I see wrong for it is the ground to the ACC wire, where would this go?
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Check this thread
    Powering UPS from inverter.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Maximum Bitrate none's Avatar
    Sep 2003
    A complicated and expensive way to do something simple. And how are you going to start the computer?
    By the time you buy all those parts you could have afforded an Opus.
    Nov 2003
    I have the inverter, I can pick up a UPS for about $80 and a relay is $20 at the most expensive normally they are $7
    Raw Wave
    Jun 2003
    Ok this is what you done wrong :
    Your relay is switching the negative side of the battery to your inverter. Try to stick to standard by switching the positive side instead.
    The ACC put out a +12V, I see you connected this to the relay coil. You must therefore connect the other end of the coil to GROUND.
    Your circuit would just turn your inverter on controlled by the ACC line. Remember when you crank the ACC line do get cut off.
    Dec 2003
    I agree with Ricky in that you need to ground the other side of your coil. However switching ground (even though "unstandard") will work fine, and is actually done more than many think. Most window motor control, car door locks etc switch ground. This is because keyless entry decoders create a closure to ground when activated and float when not activated.
    Even with that going for you, you're still hosed.
    This would work to turn off the computer ONLY if you set the UPS to shut down the computer when line voltage was lost.
    However, this wouldn't start the computer unless you found a way to get the UPS to auto-start the computer when line voltage was re-applied.
    Then the question remains as to how long a UPS will run switched on, with the computer switched off (still drawing power as we know power supplies still draw current even when their off) without line power to keep the battery charged.
    Nice try though...
    2006 Chevy Colorado: VIA M10000 EDEN, 1 GB RAM, 80 GB 2.5" Seagate HDD, USB Slim Slot DVD/RW, Holux GPS, MobileVU 10.4" LCD (touch not working yet), VOOMPC Case (blue), 70W DC-DC supply.
  1. prob with mucha shutdown controller
    By geebee in forum Power Supplies
    Last Post: 12-08-2004, 10:30 AM
  2. why use a shutdown controller???
    By cyjad in forum Newbie
    Last Post: 12-04-2003, 05:49 AM
  3. non-proper shutdown... window settings jacked
    By nadir_s in forum Software & Software Development
    Last Post: 10-31-2002, 02:15 PM
  4. New Idea for an awesome atx shutdown
    By moahdib in forum Power Supplies
    Last Post: 07-03-2002, 12:42 PM
  5. startup shutdown etc.
    By marsjell in forum Power Supplies
    Last Post: 06-19-2002, 07:07 PM
