Results 1 to 10 of 10
Thread: Wattage Calculator
    Dec 2003
    PA
    Wattage Calculator
    I've seen different threads trying to calculate wattage for systems and I remember this site.
    http://www.jscustompcs.com/power_supply/
    Great site, but it's a tad limited when it comes to powering stuff like LCDs and other carputer stuff.
    Good generalizer though.
    Maximum Bitrate deadweasel's Avatar
    Nov 2003
    Detroit MI
    HOLY CRAP! Thank you! I've been needing something like this! Now I know for sure that my rig will work with my DC/AC inverter (and that OPUS would die like a diseased skunk on a busy freeway).
    The ALEXIS Project
    MP3---VIDEO---GPS---REARVIEW---OBD---SKINNING
    Color Coding :
    DONE / MOSTLY DONE / BASE FEATURES / WORKING CONCEPT / NO CODE COMPLETED
    Low Bitrate aultl's Avatar
    Sep 2003
    Tennessee
    I have always used this power calculator, of course it is only for EPIA mobo's...
    http://www.mini-box.com/powersimulator.html
    Aultl
    [====---] - 65% complete
    Status: Configuring Software
    VIA Epia 800mhz, 256Mb ram, 10Gb HD
    Quote of the Month: "I see the problem, [The RAID controller] is trying to rebuild the array with good data from a failed drive." -- HP Support
    Newbie djjazzman's Avatar
    May 2003
    MS
    This use to be a sticky awhile back. I have been using it for a general idea. I am getting a big difference between the two. The jc site says 200 i know that is everything running at max all at once. The other gives me 88 hummmm guess I can't get by with the 70a now.
    http://www.mymp3car.com/MP3Car/PSUpower.asp
    Dec 2003
    PA
    DJ, wow! Nice calculator. I never came across that calculator. I remember searching for a couple days for a wattage calc before I even found the JS one. I know the JS one is a bit extreme but I think they do that for margin of error/boosting sales for bigger PSU (note that they are system builders). Plus, if you look at the code, about 1/3 of the way down they have this line:
    objForm.total.value = parseInt(intTotal*1.3) + 36;
    It's the string to total the wattages, but why multiply by 1.3? Any ideas on this?
    Raw Wave
    Jun 2003
    For margin mainly.
    For example a HDD or DVD rom spinning up needs alot of current, then after they stablise to the normal consumptions. Infact device do need larger current at initial switch on. A bit like accelerating a car thats when you used up alot of fuel after a steady speed is reached fuel consumption goes low.
    The high margin just ensure that the PSU built-in current limiter never get tripped otherwise a complete PSU shutdown may occur.
    Maximum Bitrate owenjh's Avatar
    Nov 2003
    NC
    I do not think that calculator is correct. I will see when I get my system up and running
    CarComputer Status: New Car & Broken (Motherboard Fried)
    Owen JH | My Linux Blog | The Tech Fellows
    Maximum Bitrate jusatry's Avatar
    Nov 2003
    Question
    Quote Originally Posted by aultl
    has anybody had any problems with this calculator?
    when using it is it usually short or long of the "actual number"?
    TIA
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    It would be nice if we could get a sticky of DCDC setups, and actual current draws while the systems are in heavy use.
    Anybody see a problem with using an Opus (powering Mobo, internal devices, HDD) and a relay to turn on a PW-70A, and then use the PW-70A to power all of the external hardware and optical drives?
    Fabricator
    Jul 2003
    So. Cal.
    Quote Originally Posted by Altimat
    that crazy enough to work. I know I decided to stop calculating on the jsc calculator when i was at 251w. I guess i'll just order the opus150 from here and pray.
    AMD 1800+ XP
    256MB SDRAM
    16x DVD
    GeForce4 440mx
    40GB 5400rpm
    will it handle all that?
  1. TM701L wattage?
    By Muzza in forum LCD/Display
    Last Post: 11-29-2003, 12:10 PM
  2. EPIA ME6000 audio wattage . . .
    By omniphallic in forum General Hardware Discussion
    Last Post: 11-27-2003, 05:13 AM
  3. what kinda wattage do i need?
    By GrendelT in forum General Hardware Discussion
    Last Post: 08-30-2000, 02:05 PM
  4. Anyone used a TI-8X Calculator to keep track of lists?
    By ToMaC in forum General Hardware Discussion
    Last Post: 03-26-2000, 05:03 PM
  5. recommended wattage on power inverter
    By flipSyde in forum General Hardware Discussion
    Last Post: 08-10-1999, 11:16 AM
