Results 1 to 6 of 6
Thread: Aussies seen this? Morex DC-DC 12V Power Supply
    Dec 2003
    Sydney Australia
    http://www.qctech.com.au/proddetail....U-Morex-DCtoDC
    Morex DC-DC 12V Power Supply.
    Morex DC-DC converter to convert 12V to ATX power for motherboard use. Cables included.
    Price: $68.20
    anyone used one??
    any aussies got a good shutdown controller? or know of where to get them here?
    damn it US has alot more of this stuff then aussie ehe
    Variable Bitrate NJay's Avatar
    Mar 2003
    UK
    That's exactly the same one as in my Procase 3688 and after a few discussions on here it needs 11.4v-12.6v, i.e its not recommended to hook it directly to the car's 12v supply as that can get as low as 7v while cranking the engine and as high as 18v during voltage spikes.
    Dec 2003
    Sydney Australia
    ahh cool thanks
    damn this stuff isnt very common in aus yet
    Aug 2003
    Orange County, NY
    Quote Originally Posted by NJay
    The one thing that hasn't been addressed.. for those of us powering epia boards with laptop hard drives, are these safe to use directly in the car? Since the 12volt line isn't required by the motherboard nor the hard drive everything will be powered off the 5volt and 3.3volt busses. Do these voltages stay stable during the cranking/running cycles in vehicles?
    just a random thought...
    Aug 2003
    Perth
    DC-DC Regulator
    If you are looking for the morex power supply:
    The DC-DC daughter board is $46+gst and power adaptor is $36+gst, ask for
    Richard Hung
    PCI Case Group Australia P/L
    Tel: (02) 9648 1138
    Fax: (02) 9648 1137
    E-Mail: sales@pcicase.com.au
    Web: www.pcicase.com.au
    I am in the process of putting it all together, I have used the Morex 3677 case and one of these:http
    //www.computronics.com.au/meanwell/sd-50/
    The SD-50A-12.
    Seasons greetings to you all.......
    Nov 2003
    Marietta, GA
    Jason...are you sure about the 12V not being used by the motherboard? I'm not doubting you, I have just never looked into it. If so, this could explain why some of the (brave) folks are successfully running their internal Casetronics/Morex PSU directly from their car battery (ditching the brick). I would assume that the regulators in the internal PSU would be able to tolerate a wider input range than the +/-5% that Casetronics states in their specs.
    Could you double-check the 12V thing and let us know. This may give us more freedom on a way to kick the brick.
    MikeH
  1. DC power supply...HELPPPPPP
    By walid_bmw in forum Power Supplies
    Last Post: 10-02-2003, 01:26 PM
  2. morex dc dc power supply again
    By susman in forum Power Supplies
    Last Post: 04-12-2003, 02:39 PM
  3. zootjeff's DC to DC power supply and hard drives
    By Squeezer in forum Power Supplies
    Last Post: 11-05-2002, 08:50 PM
  4. What are the ATX DC to DC power supply options?
    Last Post: 07-08-2002, 04:25 PM
  5. dc to dc ATX power supply
    By Kaizer Soze in forum General Hardware Discussion
    Last Post: 10-21-1999, 07:47 PM
