Results 1 to 3 of 3
Thread: Grounding the PC when using an inverter?
    Apr 2003
    Tucson, AZ
    Is there any harm in a setup like this. I have a DC to AC inverter and I wanted to ground the PC to the car. I tested the inverter to see if it did this in its circuit, and it doesnt. I can understand why?....because it an isolates the DC from the AC sides of the circuit.
    My reason for wanting to do this is so I can use the PCs PS 12V lead in my shutdown controller.
    If anyone has any knowledge on this, it would help greatly.
    1999 Ford Contour SVT
    Via M9000
    Apr 2003
    Tucson, AZ
    I think i answered my own question. The converter (i think thats the right term) that came with the PC should also be a isolation circuit. In other words, grounding the PC does not ground the AC side of the circuit so everything should be safe.
    Via M9000
    Raw Wave hijinks21's Avatar
    May 2002
    Albany, NY
    are you grounding your inverter to the car frame? if so do that and then ground your PSU to the same spot as the inverter. Take a screw that holds the PSU to the case
    '98 Explorer Sport
    80% done
  1. inverter or DC PC Power supply?
    By qdrw82 in forum Power Supplies
    Last Post: 11-07-2003, 06:00 PM
  2. inverter making pc do werid stuff
    By pcman in forum Power Supplies
    Last Post: 11-08-2002, 11:51 AM
  3. inverter delay to power on pc prob
    By felix99 in forum Power Supplies
    Last Post: 06-26-2002, 03:40 AM
  4. Have to switch inverter off and on to power up pc
    By mbowler in forum General Hardware Discussion
    Last Post: 08-22-2000, 12:00 AM
  5. Laptop inverter works in a desktop pc?
    By prado_sergio in forum General Hardware Discussion
    Last Post: 10-11-1999, 10:56 AM
