Results 1 to 10 of 14
Thread: Shutdown Idea for those without hot switch
    Maximum Bitrate owenjh's Avatar
    Nov 2003
    NC
    Ok, just relised that my motherboard does not have that thing where you push the power button and it turns off, so i had the idea of making somthing that attaches to the serial port or parrallel port and then putting that to the shutdown controller instead of the 2 mother board pins, would anyone know how to go about doing this??
    CarComputer Status: New Car & Broken (Motherboard Fried)
    Owen JH | My Linux Blog | The Tech Fellows
    Raw Wave
    Jun 2003
    Wake-on-ring with "fake" UPS on serial port
    or...
    If you are very technical and can design your own magic packet emulator the wake-on-lan is a neat idea.
    Variable Bitrate dbinnc's Avatar
    Sep 2001
    Greensboro, NC
    I will be trying this idea
    serial port shutdown signal
    I have written the vb code already too.
    Rob
    Rob is offline
    Maximum Bitrate Rob's Avatar
    Aug 2001
    Missing In Action
    Serial Port Buttons
    A one point I was playing with this hardware / software combo,
    http://www.basementfreaks.com/member...ojects/serial/
    http://diba.hotbox.ru/comctrl/index.html
    and if I remember correctly it has a shut down function, there is (was?) also a plugin for Winamp which causes it to auto shut down the PC when you exit.
    And you say people actually pay money for M$ Windows?
    www.mp3mini.co.uk (Does what it says on the URL) www.openclassic.co.uk (The new car, with zero rust!) www.rob-web.co.uk (My other site)
    Total re-design underway: on the whole progress is very slow as the car is taking up too much time :)
    Nov 2003
    NC
    Yes, well now I have my LCD and all I need to buy is the wire I think I am just going to use another motherboard thats the easy way out :-D
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    Quote Originally Posted by owenjh
    i use girder for this, i got ignition connected to a relay so when ignition is OFF the relay is closed and hence a button is "pushed" on the serial port, you need the serial plugin for girder, wiring diagram is included. i have it set so if my ignition is off for more than about 4 seconds the computer shuts itself down (gives me time to crank the engine)
    Sep 2001
    Greensboro, NC
    you talking about this serial plugin? only one I found. http://www.girder.nl/serial.php
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Quote Originally Posted by 2k1civic.com
    http://www.girder.nl/downloadn.php?Link=297
    Nov 2003
    Colorado
    Quote Originally Posted by Nic
    Do you still have to manually turn on the computer, or is it also possible to "wake" the computer via switches wired to the serial port?
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Quote Originally Posted by sigma957
    i dont think its possible without using wake on ring for modems, which means sending modem commands not using switches, i attatched my power button to my central locking, so the pc starts booting when i unlock my doors, so long as i get in and turn my key in the ignition the computer stays on, otherwise it powers itself off
  1. ATX shutdown controller kit / assembled for sale
    By Mastero in forum Classified Archive
    Last Post: 01-27-2004, 01:33 PM
  2. Idea for a shutdown controler
    By owenjh in forum Power Supplies
    Last Post: 12-14-2003, 10:45 PM
  3. Help With Extending Laptop Docking Station's Power Button
    By JeffesonM in forum General Hardware Discussion
    Last Post: 04-14-2003, 01:13 AM
  4. New Idea for an awesome atx shutdown
    By moahdib in forum Power Supplies
    Last Post: 07-03-2002, 11:42 AM
  5. ATX power switch
    By mtmsol in forum Power Supplies
    Last Post: 05-13-2001, 12:22 PM
