Results 1 to 10 of 11
Thread: Opus wattage question
    May 2003
    Texas
    Can someone let me know which power supply I should go for? 90watt or 150watt? This is my current setup that I need to power with a DC-DC power supply:
    EPIA M10000
    20gig HD
    slim DVD drive
    USB mouse
    No-name Wireless Lan Card
    SoundBlaster Extigy (needs to be powered off the computer 12V)
    DSCustoms 7inch screen
    Future upgrade: GPS
    If there is a better solution from another company please let me know. I have a shutdown controller on the way, but I might sell it if the power supply I get has one in it. I have tried 3 different "cheap" solutions and I just want to get what will work and hopefully spend under $200
    Constant Bitrate psyclobe's Avatar
    Oct 2003
    I went 150watt, no problems here.
    May 2003
    Texas
    Is the 90 watt smaller? Also, can someone point me in the direction of some pictures showing the actual size of the power supply? Maybe it next to a CD or something? Thanks.
    Maximum Bitrate tom2112's Avatar
    Nov 2003
    Sharon, PA
    Quote Originally Posted by ELEmental59437
    The 150 watt supply is larger than the 90 watt. The 90 watt is 17.5 cm by 7.8 cm (8.2 cm with bracket) by 2 cm. I don't have the measurements for the 150, but from the looks of it, it's mainly taller.
    Note, my 90 watt pictured has the optional mounting bracket.
    So far:
    M10000 Nehemiah, 1Gb RAM, Opus 90w PS, Buffalo Tech WLI2-USB2-G54, 160 Gb HDD, GlobalSat BU-353 GPS, iGuidance, Zippy EL-610, Panasonic CW8123B Slim Slot CDRW/DVD, 10" Lilliput, Sony XA-300, Sony CDX-MP30 Head, OBD-II
    Nov 2003
    Sharon, PA
    Here's a pic of the 150 watt. From the size of the ATX power connector, you can tell that this supply is a bit wider than the 90 watt, and much taller.
    EDIT: Opus' site says that the 150 is 100mm x 125mm x 63.5mm including enclosure.
    So far:
    May 2003
    Texas
    Thanks for the dimensions tom, and nice cd.. lol
    I think I could get the 90 watt in my case with no problem, only wonder if it has enough power for what I need.
    Nov 2003
    Sharon, PA
    Cool
    I thought you guys might like that CD. I know I do.
    I wish I could tell you for sure that it'll be enough power for you, but I don't have mine installed yet. I'm waiting on the screen to come in. The numbers look good for the 90 watt and my setup, but it'll be close.
    Our setups look real similar, except for the Extigy. I'm even going to use a full size CDRW/DVD drive, so mine should be more power hungry than yours. I figure mine at approx 75 watts. You can guesstimate yours by going to www.mini-itx.com and scrolling to the bottom of the right-most column. You'll see a sections of "Useful Links" and a "Power Simulator". This will let you select your mainboard and peripherals and tell you how much power they will draw. It's estimated, since specific devices draw different power, but I think it's good enough to work for us. Use the "Play DVD mode" for the highest amount of power useage.
    So far:
    Nov 2003
    Sharon, PA
    I just thought of something else too. I was planning to power my screen from the Opus supply. (not included in the 75 watts I mentioned above) Anyone know how much power the DWW-7VGA pulls?
    Is this a good idea or bad idea?
    So far:
    Oct 2003
    I plan on doing the same thing, using the power from the opus to power everything-dww-7vga, cd/dvd rom, all up front-of course I got the 150watt psu just to be sure ;P
    -Jason
    Variable Bitrate Sh0cker's Avatar
    Aug 2003
    LI, NY
    im powering everything from 150W opus, this includes all the computer parts plus LCD display which is a 10.4" allbrite with 4bulbs - monster ;d
    Danny.
    "If today was perfect, there would be no need for tomorrow."
    My Car Project® ‹== !10.4" Allbrite, touchscreen, epia, 150opus, gps, wireless, sony remote [old] 128x64 Crystalfontz +double din [new]
  1. Replies: 109
    Last Post: 05-31-2004, 10:07 PM
  2. One reason not to buy the Opus
    By orangewhip in forum Power Supplies
    Last Post: 03-13-2004, 05:15 AM
  3. OPUS 150W Question
    By belezeebub in forum Power Supplies
    Last Post: 12-23-2003, 03:56 PM
  4. fan directly pointed on an opus?
    By samc in forum Power Supplies
    Last Post: 08-21-2003, 09:36 PM
  5. Opus Question
    By Daz in forum Power Supplies
    Last Post: 07-03-2003, 06:24 AM
