What do you guys think of this car adapter?
http://www.targus.com/us/product_det...?sku=PAPWR200U
Well, I found it for $85 dollars and for 120 watts of power... the others sell for $50 - $60 for a max of 60 - 70 watts of power... I would think it's comparable, no? Anyone else have any thoughts?
That is cheap for 80USD...last time I paid about 140USD for the older verions of targus adaptorIts only 60-70W as far as I can remember.
Crav,
I you download their spec sheet you will see that the unit is rated for 6Amps max. At 12V this works out to 72Watts. Theh 120W claim is probably at 20V output. However, depending on your system configuration, this (6A) may be enough. I use the Radio Shack version of this same type of supply ($60).
MikeH
Exactly the answer I was looking for. Thanks manOriginally Posted by MikeH
Can someone tell me what tip number t use for c134 ie 12 volts
ALIBABA - I30 99
Nemiah M10000, C134
DVD, 40Gig, 256MB DDR
GPS, OBD 2, Reverse Cam
Mute on stereo w I300 car kit
Liliput 7in w usb touch screen
Direct connect with BOSE-CD changer
Does tip have anything to do with voltage? I'm not positive, but i'v got one laying around, it's my dads. I know the pw70a takes a 3p, but i didn't think it had anything to do with voltage. to someone who knows, i probably sound really dumb, but that's what the pw70a takes according to logicsupply, they sell the brick.
My Carputer! (More Car Pics at the end)
2 Kicker Comp 10"
Epia M-9000, 256 MB DDR, 120 Gig HD
Lilliput 7" VGA Touchscreen
Check it out?!
Targus supplys are configurable from 3 volts to 24 volts, configured by the pins they use..... each pin has a number associated to it
ALIBABA - I30 99
Nemiah M10000, C134
Where did you find the spec sheet ...... I am looking for it as well as a tip number for the casetronic c134
Also How long have you used the Radio shack PS and have you had any issues ie heating up and or low voltage during boot up?
ALIBABA - I30 99
Nemiah M10000, C134
