Results 1 to 10 of 15
Thread: does anyone have a shutdown controller design they can share?
    Oct 2003
    Philly, PA
    I want to build my own shutdown controller, does anyone have any schematics for one?
    Pontiac Grand Am
    building CarPC useing BookPC and Lilliput 7 inch TS.
    Nov 2003
    Marietta, GA
    Check out page 14 of this
    MikeH
    mst
    mst is offline
    Constant Bitrate mst's Avatar
    Nov 2003
    France
    Thumbs up
    Thank you very much for your link,it is a MUST read for all with Epia Mini-Itw motherboards
    Quote Originally Posted by MikeH
    Oct 2003
    Philly, PA
    is that just a shutdown controller? or also a tank circuit?
    Pontiac Grand Am
    Nov 2003
    Marietta, GA
    DJ
    Are you referring to the ITPS? It is a turn-on/shoutdown controller plus a (somewhat unusable) 12V regulator. As I understand, a "tank circuit" usually consists of a diode feeding a large capacitor, which attempts to hold enough charge to continue feeding 12v to you carpc during engine cranking. The ITPS DOES NOT do this. However, they have recommended the following as a way to help overcome the crank issue. This approach should work much better than a capacitor:
    MikeH
    Raw Wave
    Jun 2003
    MikeH,
    Some has already tried this solution, and surprised the ITPS barely work. This is due to the fact that the ITPS already need 13.3V atleast to output a regulated 12V, loosing another 0.6V throught the diode make the matter worst.
    The battery symbol is drawn funny
    Oct 2003
    Philly, PA
    i just want a design simmilar to jeffs...
    Pontiac Grand Am
    Nov 2003
    Marietta, GA
    Ricky
    Agreed, but I have bypassed the onboard 12v regulator. I'm using the laptop (Radio Shack) regulator before going into the ITPS. Therefore, there should only be a .1v drop across the switching FET on the ITPS. If my backup battery is fully charged, I should be able to get 11.3v+ or so (marginal, but should keep the mobo from rebooting) at the output of the ITPS during cranking. Obviously, I haven't tried it yet, so I'll let you know how it works when I do.
    Yeah, looks funny to me too. It should have more cells...looks like an asymmetrical capacitor.
    MikeH
    Oct 2003
    Philly, PA
    all i wanna do is build a fairly simple shutdown controller.
    Pontiac Grand Am
    moahdib's Avatar
    Jul 2000
    Check out my "old" mp3car project page. In the hardware section you should see Jeff's shutdown controller (original) which I built a first working prototype of and its schematic.
    http://home.comcast.net/~danielsoh/shutdown.htm
    04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
    Fast car, fast PC. ;)
    http://www.arcdesigns.net/carpc/
    My TL CarPC ver2
    FSR Flash Skin w/ moving weather maps
  1. prob with mucha shutdown controller
    By geebee in forum Power Supplies
    Last Post: 12-08-2004, 10:30 AM
  2. ATX shutdown controller kit / assembled for sale
    By Mastero in forum Classified Archive
    Last Post: 01-27-2004, 02:33 PM
  3. why use a shutdown controller???
    By cyjad in forum Newbie
    Last Post: 12-04-2003, 05:49 AM
  4. Cold shutdown controller!
    By phil.45 in forum Power Supplies
    Last Post: 01-13-2003, 10:46 AM
  5. Need help hooking up shutdown controller
    By MAJALO1 in forum Power Supplies
    Last Post: 10-08-2002, 02:27 AM
