forget what you heard cause its all BS.
Get your power for the inverter from the battery and ground the inverter to the car frame. Then make sound wire and ground your PSU to the same spot as your inverter. You shouldn't need to ground your mobo.. but if you still get some noise then ground that to the same spot also. The problem if you ground to two many different spots is you create a ground loop which is a bad thing
LinkBack URL
About LinkBacks
, but it's something people overlook...
