I think you will need a wire going from the Opus to the motherboard for hotswitch. If you do not have a monitor, you will need to buy one. For sound you can either wire directly to amps, or you can wire it to your head unit or use a FM modulator / transmiter. Really tho it all depends on where you are putting your motherboard for minimal wiring, for instance you will be using alot of wire if you mount it in the trunk whereas if you put it in the glove box then you will be able to hide all the wires. So decide where you are going to mount it.
LinkBack URL
About LinkBacks
