Results 1 to 4 of 4
Thread: ITPS & PW120 question
    Oct 2003
    Ok well I understand there may be an answer for this already.... I could but its 2AM and I am lazy. I have a quick question... Do I need to put a fuse between my battery and ITPS & PW120? or just hook it directly up to the battery w/ out a fuse. And if I do have to put a fuse on there what size would you suggest.
    Flame me if you want for not searching but I'm looking for the quick answer... and I do thank you in advance.
    New CarPC on the way again I think. I miss my old one!!!
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    Well, I watched a car burn to the ground outside the Gresham Theater once, because when the thiefs stole the stereo stuff, they dropped the hot wire and ran. Ever since then, I have been a firm believer in fuses and circuit breakers. Why not at least go for a 15-20A circuit breaker or so just to be safe. Way overkill, but should protect the important stuff...IE your car
    I think we agreed that a 5 amp or so would be plenty, but it is one of those things where upon startup, spikes may be higher than the 5A. I am going to use a 15A.
    2005 Ford Focus ST
    Raw Wave
    Jun 2003
    If you are draining 5A max, 7.5A blade type fuse should be fine. You can always stick in a 10A if it blows
    Go for the lowest one without the fuse blowing.
    Oct 2003
    Thanks for the quick responses guys, I appreciate it and I agree w/ ya, I'll throw a fuse in the line.
  1. ITPS-Auto Power Sequencer as Shotdown Controller
    By Nellor in forum Power Supplies
    Last Post: 03-16-2005, 12:24 PM
  2. ITPS problems
    By numberone in forum Power Supplies
    Last Post: 10-29-2004, 05:07 AM
  3. PW-70a $50.99 and ITPS $37.99
    By Zip-Lock in forum Classified Archive
    Last Post: 01-28-2004, 02:05 AM
  4. PW120 and ITPS help
    By R3l0ad in forum Power Supplies
    Last Post: 12-27-2003, 12:53 AM
  5. ITPS Power Sequence review
    By saito in forum The Review Palace
    Last Post: 12-18-2003, 10:26 AM
