Of Mini-Box's web site: regarding thier PW-70A
+5V - General M/B and disk circuitry, Memory,
laptop drive motors. All Boards All our DC-DC converters have adequate
power on this rail
+3.3V - CPU core, Memory EPIA-5000, 800, V, M/1000, CL, etc All our DC-DC converters have adequate power on this rail.
-5V - Obsolete NONE No longer needed on any boards.
+5SB - Memory, vital sleep functions. ALL Uses little power.
+12V - 3.5", 5.25 motors, fans, P4 power mostly P4 boards (lots of power), FET drive on all boards (little power). Use PW-60a or PW-70a only when using 3.5" drives or P4s.
-12V - Some older serial ports EPIA-M, EPIA-M2 (EPIA-5000/800/V does not use the -12V for serial ports) Check the serial driver chipset. Modern serial chipsets do not use the -12V rail.
As to "How is this easier than building a Sproggy?", I don't know.... what I wanted was to find out was if the M-9000 would work with out the +12Volt line, since this is the voltage that seems to give the most truble. As to easier, you could get this power supply down to 5 or 6 components and for $15-$20
