Page 1 of 5 12345 LastLast
Results 1 to 10 of 44
Thread: For those who tried the 1F tank!!!
    Raw Wave
    Jun 2003
    Alot of member here have noticed the big 1F question kept comming up. Newbies come and ask the same question over and over again. No one has really proved that this circuit can survive a crank.
    So for those who have built one, please post your success story so we can point this thread to the newbies whos needing help.
    Exact setup details, inverter, PSU, m/b used...etc.
    Cheers
    Raw Wave
    Jun 2003
    Wow 41 views and not a sausage?
    Anyone comming forward?
    Maximum Bitrate SjLucky's Avatar
    Jul 2003
    Meridian, Mississippi
    I think they are too scared to post...
    they need to drink like me... that way fear has nothing to do with posting it just has to do with weither or not you feel like it
    Quote Originally Posted by menudude View Post
    thank you all for your help minus the useless post by sjlucky...
    FLAC robiewp's Avatar
    Dec 2003
    Massachusetts, US
    I couldn't tell you who but someone was kind enough to post the calculations. It came out that the 1f should be able to power the mini itx system for 1/4th seccond of cranking. Not enough if you ask me!
    I'm a HUGE fane of the seccond battery with an isolator circuit that kills power durring cranking (and in my case engine off aswell). 1fs are expensive too! my rig cost me less than 50 bucks and it can run my computer for over an hour.
    car computer rev 5: 8" lilliput and usual suspects
    Jul 2003
    Im a big fan of the second battery too
    Raw Wave
    Jun 2003
    It was me who posted that calculations, good old physics book it was
    I started this thread to clear things up because that damm 1F question kept bothering me
    Raw Wave
    Jun 2003
    Im a big fan of second battery too,
    I bought 12V 0.8Ah, 12V 2.8Ah and 2x6V 1.2Ah
    The plan with the 2 x 6v 1.2Ah was to put them in series side by side in a low profile case...disnt work as I expected
    Dec 2003
    Massachusetts, US
    at places like U do it electronics you can get really nice low profile 12v (13.blah)batteries. I was able to meet the 'run your headlights for 1/2 hour' spec in converting a dirtbike with two batteries zip-tied to the inside of my leadlight casing.
    I, on the other hand, have an SUV and no problem carrying a seccond full size battery
    Maximum Bitrate none's Avatar
    Sep 2003
    Nobody has tried a 1F cap, that wasn't the idea. Someone mentioned a 1F cap when someone else said the 2200uF caps wouldn't last long enough - neither poster having tried anything (and missing the point btw.)
    The tank circuit doesn't need to power the whole setup for any time at all - it's just there to smooth out the voltage dips. The calculations being thrown about are irrelevant. Capacitors aren't meant to fully power things, but they are more than capable enough to smooth an engine-cranking voltage dip to the point that a well designed and efficient PSU won't "tank."
    The pw60/70/120 and ITPS combo are not efficient at all.
    Raw Wave
    Jun 2003
    Ok...maybe I misunderstood what tank really meant :
    So that tank circuit was just there to smooth out the "AC" components of the supply during cranking. Just as found in a power supply circuit where you have a smoothing capacitors...it will not keep the 12V during cranking.
    If smoothing was all needed then that diode shouldnt be there at all as the voltage never goes negative.
    I thought the whole idea was to survive a crank due to heavy load from the starter motor?
    Correct me if Im missing something here
  1. Newbie has a question about Tank Circuit.
    By GScherler in forum Power Supplies
    Last Post: 11-14-2003, 05:15 PM
  2. tank circuit
    By TiTUS in forum General Hardware Discussion
    Last Post: 09-07-2003, 06:05 PM
  3. tank circuit - what output do I need?
    By maxcosity in forum Power Supplies
    Last Post: 06-03-2003, 05:00 PM
  4. tank circuit?
    By jrbless in forum Classified Archive
    Last Post: 04-06-2002, 10:40 AM
  5. Advice on tank circuit !
    By Mastero in forum Power Supplies
    Last Post: 04-03-2002, 01:37 AM
