Results 1 to 10 of 15
Thread: Power to lcd?
    Jul 2003
    Earth
    Power to lcd?
    hi all i have all my bits finally!!! well i almost regret not waiting until the lilliputs came down but heh......
    I have a:
    LCD Display?.Model No. NL6448AC33-29?.10.4?
    Inverter board also included?.Model No. S-11251B
    But i am unsure of how to power the inverter....i have read the lcd pdf but it reveals no clues. Does anyone else have these items and have them running?
    I was hoping i could take power from the pc and run the inverter and thus the screen off it. But without a clue of the voltages its a nightmare....
    Any help appreciated.
    cheers
    FLAC Skraggy_uk's Avatar
    May 2002
    Warrington UK
    Power to the inverter will normally be off the controller board. This the brightness controls to be operated by OSD/buttons etc on the controller board.
    4x4 in a turbo stylee.
    Raw Wave
    Jun 2003
    From having seen alot of laptops inverter theres normally 2 connectors on the inverter board. Usually theres the HV and the controls connector, the HV goes directly to the screen backlight.
    Some uses 5 or 6 wires. 2 of the wires is obviously the supply voltage. If you are really stuck, try to read off the part number of the chip (IC1) then try to get the datasheet. If you can atleast find out which pin are the supply voltage for this chip and then trace back to the 5 wires then you are atleast 2 wires down
    You can easily find out which is the ground by tracing a big grounded copper on the PCB back to the 5 wires, normally the mounting hole are earthed, so you can be sure where your earth is.
    Apply the voltage required to this chip as stated on the datasheet. The rest of the wires you just have to guess what they do.
    Thats all I can help you...good luck
    Or did you already knew which is the supply voltage for the inverter but dont know how much to apply?
    Jul 2003
    Earth
    Quote Originally Posted by Skraggy_uk
    I bought a controller board from mileselec....and a Hirose cable for the screen, i am assured it will work with my screen but i see no way of powering the inverter from the controller. The cable that pretrudes from the inverter goes into the screen, on the other side there is another sockert so perhaps i need another cable? to plug into my controller?
    http://www.milesie.co.uk/shop/asp/pr...sp?Product=291
    Jul 2003
    Earth
    Quote Originally Posted by Ricky327
    I havent been able to find a data sheet for the inverter at all.....the pdf for the lcd does mention an inverter, and i assume its the one that came with the screen but it make no mention of its part No.!!!
    http://www.lcdspecifications.com/nec...448ac33-18.pdf
    It does use Vddb as a reference to the supply voltage and later on its says vddb = 12v but i have no idea of ampage or where to get the power from!!
    May 2002
    Warrington UK
    Quote Originally Posted by Blop
    I think this is the same controller.
    And it shows a setup for the inverter.
    Jul 2003
    Earth
    mmm it looks like it plugs in at the top.....im sure i had a good look and decided that inverter plug wasnt going to fit anywhere. ill give it a through going over tonight when i get back.
    Cheers for your help skraggy.......
    May 2002
    Warrington UK
    You might need to hack about a cable with a Maplin connector to fit the panel.
    As long as the panel's back light voltage, and the inverters requirements are the same (i.e. 3.3v, 5v, 12v etc) and you get the polarity right, you should be able to knock something together.
    Jul 2003
    Earth
    ok ill have a look. Wont the ampage matter?
    May 2002
    Warrington UK
    ISTR that most panels have an input requirement of of only a couple of AMPS. Should be marked in the PDF somewhere, and on the inverter board.
  1. LCD won't signal MB to power RCA out
    By tropez in forum LCD/Display
    Last Post: 10-23-2003, 04:13 PM
  2. lcd power
    By traitorhound in forum LCD/Display
    Last Post: 07-17-2003, 05:44 PM
  3. Doubt before buying an power acoustik lcd screen
    By cyrofilho in forum LCD/Display
    Last Post: 06-01-2002, 10:40 PM
  4. LCD power question
    By BRINET in forum LCD/Display
    Last Post: 04-20-2002, 01:34 PM
  5. LCD power, which pin?
    By dudah85 in forum General Hardware Discussion
    Last Post: 05-10-2001, 06:35 PM
