Page 25 of 25 FirstFirst ... 1516171819202122232425
Results 241 to 242 of 242
Thread: Battery based tank circuit (tested)
  1. #241
    Dec 2007
    i did find some diode/rectifiers that have a 10A or 15A with low voltage drop
    i think for the price of $1-3 is good enough some come in a dual package, but i think that would create more heat? and having separate units with a higher max is better choice? in theory lower current load == lower thermal output? or no...
    at i was able to search for a few .33v up to .45 and if you wish even .5 which case your able to get very high voltage and high current max
    would something like this work good?
    2x of those or one of these?
    i think the .5v drop ones are more readily available?
  2. #242
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    I would have thought somethign like this would work well
    no resistor, but a relay in there so once you turn the car off the PC cant draw any more power from the cars battery
  1. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
  2. Tank Circuit Voltages
    By ciagon in forum Power Supplies
    Last Post: 11-23-2003, 04:45 PM
  3. Newbie has a question about Tank Circuit.
    By GScherler in forum Power Supplies
    Last Post: 11-14-2003, 05:15 PM
  4. tank circuit
    By TiTUS in forum General Hardware Discussion
    Last Post: 09-07-2003, 06:05 PM
  5. tank circuit - what output do I need?
    By maxcosity in forum Power Supplies
    Last Post: 06-03-2003, 05:00 PM
