You're definitely NOT wrong to fear sending unregulated voltage to the screen and motherboard. Not only does the PW-70 not regulate the 12volt line, but under some circumstances it does not properly regulate the 3.3v or 5 when seeing 13.8! To say that I don't use the ITPS is not to say that I send unregulated voltage to the PW-70. I considered it as a possibility, but after some testing found that when 13.8v powered the PW-70, by whatever act of nature and god, the vt6103 chip (lan) was getting voltages outside of its tolerances. This was the only chip I checked, but I would not be suprised if there were more. Even if you're not noticing problems with unregulated current does not mean you arent' slowly killing your computerOriginally Posted by mst
I have the fine motor skills of crack fiend so I shy away from soldering intensive stuff, though i can manage most of the time (you do have to build the sproggy, right?)
LinkBack URL
About LinkBacks
