Ricky,
In your original post (schematic), shouldn't your top diode (from main battery/alternator) be on the OTHER SIDE (left side) of the current limit resistor? If not, won't current begin flowing from your backup battery to the main battery during cranking, limited only by the resistor? This would effectively drain the backup battery if the main battery drops significantly during cranking, and may pull the backup battery's voltage down with it. The current drain is not the issue, but pulling down it's voltage may be enough to reset our pc.
Perhaps I'm not understing this correctly........![]()
LinkBack URL
About LinkBacks
I'm 55!
The PSU is named for an early member of this forum who designed it in the first place. Mastero currently markets a variant or two. I think his 2.8+ version is the best - that's why I have 2
