Good Afternoon.
Hopefully someone can help me out. I have an Epia 800, ITPS, pw60 and a 12v motorcyle battery.
I connected the battery to the pw60 but the Epia will not power up.
I figured the board was receiving too much power, so I purchased the ITPS. I then placed that between the battery and the pw60 (obviously), but it still will not work. I also tried using a fully charged car battery. No luck.
I will not be installing this board in a Car. It will be installed in a scooter, but it will not be incorporated into the electrical system (yet). So, it will be standalone, with it's own battery. Therefore, I will don't know where to plug the 'ignition' wire (red wire) from the ITPS. For now it's connected with the white wire to the positive terminal.
Any Ideas?
I know the board works fine because it powers up properly with a standard ATX power supply.
Thanks in advance.
Motorcyle Battery: 12v, 5Ah
Car Battery: not sure.
Board: Epia 800, 40mm fan, 2.4 HDD, 5.25 CDROM, 256 RAM.
PS: pw60, ITPS.
Semper Ubi Sub Ubi
