Results 1 to 10 of 16
Thread: Inverter cutting out
    Low Bitrate telstargb's Avatar
    Aug 2003
    Leicester, UK
    I have just installed my carputer, an Epia 800 with 40gb 5400 rpm drive. This is powered by a 150w inverter connected through the cigarette lighter socket. It works faultlessly for about an hour then cuts out. At this stage the inverter case is quite warm, but I wouldn't say it is too hot. Prior to installation the system worked fine in the house for hours on end, so I presume its the inverter causing the problem, but as I would guess that the system is not drawing anywhere near 150w wonder why the inverter should cut out.
    I intend to get an Opus when I can locate one or get one shipped to the UK but understand from previous posts that this could take a while, so would like to solve this.
    Can anyone help?
    telstargb
    Raw Wave
    Jun 2003
    Check the contact between the cigarette lighter socket and the inverter plug...it may not be making good contacts.
    Otherwise your inverter maybe faulty, or have over heating problems.
    Low Bitrate crosseye's Avatar
    Dec 2003
    Syracuse, NY
    Not too sure why that might be happening... I just picked up a 400 watt inverter for $30 (USD) like half an hour ago to use as an interim solution. The inverter came with battery clips and a cig lighter adapter. Since the inverter is 400 watts, i'm going to hardwire it right to my battery similar to how you'd hardwire an external amp.
    Maybe you could try this? My thought would be that the wires leading into your cig lighter are not able to handle 150 watts... i could be wrong tho.
    It's worth a shot. If your inverter has battery clips, just try connecting directly to the battery and running the PC for awhile while its in your driveway or something.
    Keep us posted.
    Low Bitrate Wolfman's Avatar
    Nov 2003
    East Texas
    is this with the vehicle running? my inverters shut down when there is a voltage drop due to a low battery
    Aug 2003
    Leicester, UK
    Wolfman - yes its with the engine running. I have about an hours journey to work and it always seems to cut out just before I get to my destination. (Guess I'll have to get a new job only 1/2 hour away - LOL)
    Ricky327 - I pondered on the contact between socket and plug. It seems to be fairly solid and surely it wouldn't last as long as 50 - 60 minutes before cutting out if it was faulty. Crosseye - no there are no battery clips, but I guess I may have to hardwire to the battery to see if that solves it. Could be the inverter is faulty and overheating but as I said in original post the inverter case does not feel too hot when it cuts out.
    Thanks for your quick replies guys.
    telstargb
    Raw Wave
    Jun 2003
    I meant there maybe some slight resistance between contacts. Heat is then generated in the socket and after a while it will fail and cause your inveter to cut out. Pulling the plug out sure let it cool down again and so your inverter can work again. Thats the main reason why the higher powered inverter need to be connected directly to the battery as this avoid any high resistances.
    Ok I should have really said does the cigarette lighter socket get hot
    Aug 2003
    Leicester, UK
    Quote Originally Posted by Ricky327
    Not sure about that - I'll check on my journey into work tomorrow
    FLAC robiewp's Avatar
    Dec 2003
    Massachusetts, US
    if it were a wiring problem i think it would cut out much earlier. **** inverter. A 150 watt inverter I picked up at wallmart would do the same.
    car computer rev 5: 8" lilliput and usual suspects
    Aug 2003
    Leicester, UK
    Quote Originally Posted by telstargb
    The cig lighter socket is quite hot at the time it cuts out, so I may try hardwiring it to the battery. Anyway, I've decided to order an Opus so hopefully this will only be a short term problem
    Dec 2003
    Massachusetts, US
    is it a lighted socket? Maybe it's because of its american heritage, but my Jeep's cig.lighter is damn hot all of the time because of the light.
  1. relay, inverter, fuse problems
    By cheesyhoward in forum Power Supplies
    Last Post: 06-02-2005, 10:04 AM
  2. Help with inverter
    By Starkan in forum General Hardware Discussion
    Last Post: 07-10-2004, 07:43 PM
  3. relay, inverter, fuse problems
    By cheesyhoward in forum General Hardware Discussion
    Last Post: 06-22-2004, 04:05 PM
  4. FS:HYPERION Simplicity Series standalone Controller and inverter
    By kickercivic1 in forum Classified Archive
    Last Post: 06-25-2003, 10:01 AM
  5. odd inverter behavior
    By jshrieve in forum General Hardware Discussion
    Last Post: 04-10-2001, 05:53 AM
