No it will not be able to survive while your car is cranking without a tank circuit. look for Shakes schematics i think they use the same regulator as the ITPS.
Doing some reading on here and other sites, it looks like the pw70 and the itps unit from mini-box.com will work good for my via m10000. However, I have been considering getting an opus power supply. It seems the two setups are very similar but will the pw70 + the itps regulator keep the computer on while the car is cranking?
The main reason why I like the pw70 plus the ITPS is because its small enough to fit inside the case of the c134.
Thanx
James
