Results 1 to 10 of 18
Thread: Will this inverter work?
    Nov 2003
    Constant Bitrate sabre's Avatar
    Jan 2004
    link broke?
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    I'm sure the inverter will work. It's what you are planning on plugging into it that I have no idea about. What are you going to use?
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
    Nov 2003
    http://www.bestbuy.com/site/olspage....oryId=cat08298
    sorry, heres the link
    ..and i was wondering if this inverter will work for a computer and lcd...and if the car charging port will provide enough power to run the inverter....(you wouldnt have to attach it to the car battery , correct?)
    Raw Wave hijinks21's Avatar
    May 2002
    Albany, NY
    yes that will work. Most lcds take dc power so the best thing to do is take the 12v dc power right from the PSU. On the other hand if you don't want to cut wires and worry about 12v and ground when just plug it in
    '98 Explorer Sport
    80% done
    Sep 2003
    Vic. Australia
    Gonna need more info to answer your questions properly. If you are planning on drawing the full 400watts then you would most likely need it connect it to the battery as most cig lighters are only capable of supplying 150watts (some even less). Personally I would hook it to the battery as it is safer and a more reliable connection.
    Nov 2003
    well, lets see more info.... my powersupply is 250watts, n im not sure what the monitor is....but if i connected it straigt to the battery, wouldnt the connections be loose? or become loose?....it doesnt seem like a secure connection to me.
    Sep 2003
    Vic. Australia
    You need to go down to your local auto shop and pick up a battery terminal. Use that to secure the positive line for the inverter to the battery (you will also need to buy some wire). Then connect the ground on the inverter to a point on the cars body. There should be a good few threads around that explain this in a bit more detail otherwise look at some tutorials on the net for installing a stereo amp.
    Maximum Bitrate deadweasel's Avatar
    Nov 2003
    Detroit MI
    Quote Originally Posted by grahamrb
    Want good ground? Look for a bolt somewhere near your inverter's mount point that goes straight into the car's primary body or framework. It shouldn't be something crucial like a trunklid bolt though! If it's going to be in the cabin with you, maybe attaching a wire under a seat bolt would work nicely. If in the trunk, I have always had good luck finding a good ground by putting a screw through one of the raised spars on the backside of the rear quarter panel (found behind the interior trim panels in the sides of the trunk, or again, using an existing NON-PAINTED bolt somewhere in the same vicinity. Maybe even near the brake lights...
    The ALEXIS Project
    MP3---VIDEO---GPS---REARVIEW---OBD---SKINNING
    Color Coding :
    DONE / MOSTLY DONE / BASE FEATURES / WORKING CONCEPT / NO CODE COMPLETED
    Sep 2003
    Vic. Australia
    Yeah, I attached my ground to a bolt near my brake lights, works great.
  1. relay, inverter, fuse problems
    By cheesyhoward in forum Power Supplies
    Last Post: 06-02-2005, 10:04 AM
  2. relay, inverter, fuse problems
    By cheesyhoward in forum General Hardware Discussion
    Last Post: 06-22-2004, 04:05 PM
  3. 10.4" lcd inverter
    By shaonuff in forum LCD/Display
    Last Post: 02-08-2002, 03:07 PM
  4. odd inverter behavior
    By jshrieve in forum General Hardware Discussion
    Last Post: 04-10-2001, 05:53 AM
  5. I feel like a real idiot because I cant get my inverter to work
    By gilly101 in forum General MP3Car Discussion
    Last Post: 01-31-2001, 05:44 AM
