Results 1 to 4 of 4
Thread: testing opus outside of car
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    i know this has been gone over but i cant find the damn threads in search
    i swear there was also a sticky but thats dissapeared as well
    anyway
    im trying to test my 150w opus in my home
    ive hooked up another psu to feed 12v to the opus, i have that psu on but shorting the green wire on the atx cable with a ground (via a trusty paper clip)
    the opus gets power and goes into idle state waiting for ignition (green blink every 100ms)
    i cant get past this though
    ive tried connecting the ignition line to the 12v source and still get nothing
    am i doing something wrong?
    thanks
    Apr 2003
    Did you connect the motherboard power connector from the Opus to your motherboard's Power On header ? If not, the Opus will not power on even if the Ignition wire is supplied with +12V. BTW, the connector is polarity-sensitive - if it doesn't work, switch it around.
    Mar 2003
    Rohnert Park, CA
    yes i did and the polarity is correct
    Mar 2003
    Rohnert Park, CA
    ok i got it working
    apparently you need to leave the ignition line on the 12v source for 10 seconds or so and THEN it turns on
    everything works properly now
  1. What's your dream car?
    By Aaron Cake in forum Off Topic
    Last Post: 10-02-2007, 08:34 AM
  2. power problems while car is running..
    By TimW in forum General Hardware Discussion
    Last Post: 03-18-2006, 10:11 PM
  3. One reason not to buy the Opus
    By orangewhip in forum Power Supplies
    Last Post: 03-13-2004, 05:15 AM
  4. Car Stereo Installation Video's for Sale
    By johnram in forum Classified Archive
    Last Post: 09-05-2002, 11:27 PM
