Results 1 to 10 of 10
Thread: What about 12V DC Outlets that are built into the car?
    Jan 2004
    My civic has one 12V DC Outlet in the car (it looks like a regular home outlet). Will this be able to power my comp?
    Maximum Bitrate none's Avatar
    Sep 2003
    Regular home outlets are not 12 volts DC, they are 110 volts AC in the US, 220 elsewhere.
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    If it looks like a home outlet, it'd be AC. Use "the brick" for morex's, that converts AC to 12v DC at 5 amps. Then you can plug that right into your morex/pw70a. Or if you don't have those PSU's, and you use a standard ATX PSU, you can just plug it right into that plug. I don't know much about AC in a car, but I don't think you need (or that there's any possible way/any need) to regulate it. I think since it's AC, you're good to go. Anybody else?
    FLAC shakes's Avatar
    Oct 2003
    Atlanta GA
    it's probably AC ... a lot of cars are puting inverters in now.
    i always think converting from DC to AC just to take it back to DC is a waste.
    there's many other 12v sources in your car (i.e. the cig lighter)
    My JeepPC Install
    "there are no stupid questions, just stupid people."
    "it's been agreed the whole world stinks so no one's taking showers anymore"
    Jan 2004
    AC...That's what I meant.
    May 2003
    Texas
    Quote Originally Posted by mr_anderson
    I suppose you also meant 110 and not 12 too huh?
    FLAC robiewp's Avatar
    Dec 2003
    Massachusetts, US
    Quote Originally Posted by shakes
    It's a waste of valuable amp hours, not of money... The regulation you get from doing this can be very expensive... and my inverter was cheap.
    car computer rev 5: 8" lilliput and usual suspects
    Oct 2003
    So Cal
    I would suggest you look for the output specifications to see if it can handle your pc. I imagine it was purposed for a laptop and is anywhere from 85 - 100 watts. Pay attention to the continuous and peek ratings.
    Good Luck,
    GinoRP
    VIA M-1K Nh; Lilliput 7" Touch; Earthmate GPS; Slim Slot DVD/CDRw; OBD-2.COM; ATI-Pro TV; RF Wireless KB; USB Thumb 802.11b; 7"x3.5"x7" Lexan Case; 40G Laptop HD; PW-70 w/ITPS; Headliner TV Antenna; XPHome; Delorme Streets 2003/Topo USA
    Oct 2003
    Atlanta GA
    Quote Originally Posted by robiewp
    i wasn't speaking of money. guess i should have specified
    My JeepPC Install
    Nov 2003
    Las Vegas/Henderson, NV
    The Pontiac Vibe also has AC outlets in it. I've never heard of anybody using it to power a computer though.
  1. 12V from car -> 5V 7Amps ???
    By gdunkley84 in forum Power Supplies
    Last Post: 03-06-2003, 09:15 AM
  2. Replies: 5
    Last Post: 08-20-2002, 08:32 PM
  3. car dc adapter problem
    By mr0range in forum Power Supplies
    Last Post: 11-21-2001, 07:58 PM
  4. why not to use zener to make 12V DC??
    By embedded in forum Power Supplies
    Last Post: 04-26-2001, 08:54 PM
  5. Powering a DC to DC out of the car?
    By johnram in forum General Hardware Discussion
    Last Post: 01-08-2001, 09:02 AM
