Page 1 of 5 12345 LastLast
Results 1 to 10 of 41
Thread: question for anyone currently using a battery tank
    Newbie garfin's Avatar
    Dec 2003
    I've purchased a 12 volt 5ah battery for my tank up at radioshack and have just made the logical realization that a charging lead-acid battery can release some pretty toxic/flamible fumes. Has anyone out there had any trouble with fumes or have any suggestions as to where it should be mounted? (should it have vents leading outside?)
    FLAC shakes's Avatar
    Oct 2003
    Atlanta GA
    well mine isn't installed yet ... but i put one in a guy's car and he hasn't complained yet
    i don't think it'll be that big of a deal from one battery and the tiny bit of charging you'll be doing. it won't loose much power at all during cranking so it won't need to charge much.
    I would put it somewhere in the dash or in the engine compartment/trunk if possible ... not around any air ducts
    My JeepPC Install
    "there are no stupid questions, just stupid people."
    "it's been agreed the whole world stinks so no one's taking showers anymore"
    Banned NightHunter's Avatar
    Dec 2003
    Milwaukee, WI
    It is best to install it under the hood(engine compartment). IF there are any fumes, I dont think you want that uder your dash or in the trunk. All though I have seen a lot of setups with batteries in the trunk, especially with audio system and cars with hydraulics. But if you can fit it under the hood, it is the best place.
    FLAC robiewp's Avatar
    Dec 2003
    Massachusetts, US
    Unless I'm msitakein anything from radio shack would be sealed... no worries there
    car computer rev 5: 8" lilliput and usual suspects
    Nov 2003
    Colorado
    From what I have read, no SLA battery is truly "sealed". They all have some sort of overflow valve that will vent gases if the battery is over charged or charged too rapidly. It should therefore only be charged in a ventilated area.
    I have a small SLA battery that I've mounted right in the computer case. I have it isolated from the electrical system of the car by a diode, so it does not charge in the car. Every couple of weeks I take it out and connect it to a charger to top it off, but it rarely loses much charge since it is only drawn from when cranking.
    Dec 2003
    Thanks for all of the great replies, I had not even considered putting it in the engine compartment, but that definetly sounds like the best place for a battery of this size.
    May 2003
    MA
    Question of the day for you guy's...... if you have the battery setup up and running what did you end up using for a diode (ie. source and size) ???
    Oct 2003
    Atlanta GA
    MBR3045 or MBR6045 (i think those are the part numbers) ... search digikey.com for it
    the 3045 has a lower voltage drop
    My JeepPC Install
    May 2003
    MA
    Quote Originally Posted by shakes
    I have never used a MBR 3045 type diode before.... being that it looks like a regulator LM style regulator how do you conect to it? If any one has some pictures / drawings it would be much appriciated
    T,
    VWT
    Oct 2003
    Atlanta GA
    each package actually has 2 diodes in it ... the two outter pins are the annodes and the center pin is a common cathode.
    so if you only need one diode you will only use the center pin and one outter pin.
    you can sorta see something like this in the circuit i made here ... the center pin is bent abck and soldered to that red wire ... one of the outter pins (upper) is bent around connecting to the fuse, and one (lower) is bent conntected to the resistor. i needed both diodes for this circuit. you may only need one.
    and you can get a datasheet for this diode from digikey.com ... it shows the pinout as well.
    My JeepPC Install
  1. Battery based tank circuit (tested)
    By Ricky327 in forum Power Supplies
    Last Post: 02-13-2008, 05:43 PM
  2. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
  3. One question about tank
    By Pudge in forum Power Supplies
    Last Post: 01-02-2004, 08:45 PM
  4. Newbie has a question about Tank Circuit.
    By GScherler in forum Power Supplies
    Last Post: 11-14-2003, 05:15 PM
  5. car battery question
    By detz in forum General Hardware Discussion
    Last Post: 08-07-2002, 09:10 AM
