Results 1 to 4 of 4
Thread: Powering Lilliput
    Low Bitrate telstargb's Avatar
    Aug 2003
    Leicester, UK
    Powering Lilliput
    I have an Opus 90w on order way. Can someone advise if it is OK to take a 12v output from the computer (say through a hard drive connector) to power the lilliput, or should I continue to use the grey 'egg'.
    Mondeo 1.8 Zetec : Epia 800 : 60gb drive : Lilliput 7" VGA : Sapphire USB GPS : Opus 90w : WinXP : Road Runer : Destinator
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by telstargb
    Yes it's ok. Yellow = +12 on the hdd connector
    Newbie FoxRunner's Avatar
    Dec 2003
    Ok so I have also been reding on this... Im not going to use an opus just an inverter and standard 250 watt power supply. Can I also use the HD lead?
    Nov 2003
    West Sussex, UK
    Quote Originally Posted by FoxRunner
    yes this is fine - mine is powered this way.
    in fact it is better than using the lilliput's own voltage regulator:
    i drive a manual car and when starting off the screen used to dim as the engine revs dropped, now its powered through a 90w opus and the screen brighter and never dims!!!!
  1. Lilliput install in and Impreza, Lilliput issues
    By SubPuter in forum LCD/Display
    Last Post: 04-19-2004, 09:56 PM
  2. exact outer size of 7" lilliput touchscreen?
    By cotwild in forum LCD/Display
    Last Post: 01-08-2004, 01:43 AM
  3. lilliput video In sensitivity??
    By spankmebumbum in forum LCD/Display
    Last Post: 12-27-2003, 05:25 PM
  4. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
  5. Lilliput screen + MKM1150 ¿?
    By XaCoSo in forum LCD/Display
    Last Post: 11-15-2003, 02:19 PM
