Results 1 to 4 of 4
Thread: temp. problems if inverter under hood??
    Low Bitrate cotwild's Avatar
    Dec 2003
    Switzerland
    hi all..
    would it be a problem, if a place my 2 inverters under my cars hood?
    it would be in the rear near driver cabine, save covered with plastic..
    the temperatures are going down to -10 C sometimes..
    would it be a problem??
    STATUS: planing / building
    Car: 85' Audi Urquattro
    System: VIA EPIA M10000?, GPS, WLAN, DLink Radio
    Display: 7" Lilliput Touchscreen
    Power: 300W DC/AC Inverter, OPUS?
    Sound: 7.1 Dolby Digital with Audigy2 NX
    Sep 2003
    Vic. Australia
    I would check the manual for your inverter, it should list the operating temperature. I would be more worried about the inverter overheating if it is in the engine bay.
    My inverter overheated the other day and I have it in the boot. The car was parked in the sun for a couple of hours on the 30degree day so the inside was pretty hot, but it would have been just as hot under the hood.
    Dec 2003
    Switzerland
    that's right.. i'll have to check it! (but now it's cold outside..)
    what would be the best (if i place them under the hood) for the inverters.. take them into a case? i think it's best to place them how they are...
    (the place where i would mount them is near the fuse box of the car)
    technical data of the inverter say that it's working up to 55-60 degrees celsius, but there's not listed how cold it can be...
    thx for your comments..
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    I have my inverter in the trunk of my Supra and its seem to shutdown after about an hr because of heat. Temperature is about 60-70F here in Southern Cali. If I have the window 1/2 or more down, it doesn't have that shutdown problem. If the window is close or almost close, then the shutdown problem come back. I just roll down the window all the way when it beep.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  1. Having problems with my inverter... any ideas?
    By chris in forum General Hardware Discussion
    Last Post: 08-08-2006, 10:15 PM
  2. relay, inverter, fuse problems
    By cheesyhoward in forum Power Supplies
    Last Post: 06-02-2005, 09:04 AM
  3. relay, inverter, fuse problems
    By cheesyhoward in forum General Hardware Discussion
    Last Post: 06-22-2004, 03:05 PM
  4. odd inverter behavior
    By jshrieve in forum General Hardware Discussion
    Last Post: 04-10-2001, 04:53 AM
  5. 300 watt power inverter problems
    By DaPyro in forum General Hardware Discussion
    Last Post: 03-10-2000, 02:56 PM
