Results 1 to 7 of 7
Thread: Wiring Opus outside of case
    Maximum Bitrate S4Per's Avatar
    Jan 2004
    Seattle, WA
    Question Wiring Opus outside of case
    Hi All,
    I've been doing my best to read and search, but haven't been able to find a good answer to the following:
    If the case the computer is in is too small to house the Opus 150w PS, what are my options? Is there a well known / adviseable way to mount / wire the PS? What are other people doing?
    Thanks much for any pointers, input, and advice.
    -Per
    Jan 2004
    Seattle, WA
    Is no one doing this????
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    maybe you could drill a hole in the case, put a grommet in the hole, then buy an ATX power extension, run it through the hole, hook one end to the mobo, and leave the other end for the Opus connector.
    FLAC bosstone74's Avatar
    May 2002
    Japan, Oregon
    Quote Originally Posted by binary.h4x
    remove it from it's metal case, I've seen people use there opus without a fan or it's metal case. Or build some custom housing for your comp and PSU
    BossTone74
    Maximum Bitrate orangewhip's Avatar
    Apr 2001
    Surrey, B.C. Canada
    Here is my Opus 90W that I installed. Just took it out of its UFrame and made my own mounting holes etc... Fit right in!
    Found a perfect case!
    OrangeWhip? OrangeWhip? 3 OrangeWhips!!
    www.whipflash.com
    Finally a new Avatar!
    Jan 2004
    Seattle, WA
    thanks all.
    Maximum Bitrate 00CericaRuss's Avatar
    Jul 2002
    San Rafael, CA, USA
    i have mine seperate from where the mobo is so i had to make a long atx power cable.
    solution: found 2 dead power supplies, cut the wires/connectors off, and crimped em together... it's about 2ft long
    Car: 2000 Toyota Celica GT-S
    Mods: Yep
    Carputer: VIA M9000 | Opus 150 | 512MB PC2100 | 60GB Notebook HD | Slim/Slot DVD/CDRW | Audigy2NX | Xenarc 700TSV | (2) DSCustoms DS700HRS (in trunk) | SMC USB 802.11b | CoPilot | DLink FM tuner | Cliffnet
  1. Replies: 97
    Last Post: 09-18-2006, 02:56 PM
  2. One reason not to buy the Opus
    By orangewhip in forum Power Supplies
    Last Post: 03-13-2004, 05:15 AM
  3. Mini-ITX case to hold OPUS and Epia?
    By RDaneel in forum General Hardware Discussion
    Last Post: 12-04-2003, 08:43 PM
  4. Opus + Epia.. How to get it in the case?
    By ShinkunoNamida in forum Off Topic
    Last Post: 12-28-2002, 11:47 PM
  5. Need your input on custom case
    By Adam F in forum General Hardware Discussion
    Last Post: 09-24-2002, 10:42 PM
