Results 1 to 6 of 6
Thread: OPUS - kEEP THE OPUS POWERED AFTER THE IGNITION IS OFF
    Maximum Bitrate PORTUGAL's Avatar
    Oct 2003
    PORTO
    Im planing to buy the opus 150w...
    The opus is conected to the ignition wire , and it starts the carputer when the ignition is turned on it also shuts down by sending a signal to the motherboard after the ignition is turned off.
    How do you set the opus to shutdown only at my will , i want to keep the carputer working after the ignition is off. ( just sometimes).
    I know there is a dalayed shutdown feature but i dont really know how it works ?
    Here in Portugal we have great weather, lots of brunnets, party a lot,drink a lot....
    http://img138.echo.cx/img138/896/bannerjoshua5dy.jpg
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    You can try this way. I am no expert but I think it will work.
    Car Ignition Wire -> Diode ----> Opus Ign Wire.
    Batt+ or alway on wire -> Switch -> diode -----> Join to Opus Ign Wire above.
    Normally the switch is OFF so that the Car Ign wire control the on/off of the opus as intended. If you want the opus keep operate without the key/ign, flip the switch to ON then turn off the key.
    I have similar setup for my PSU.
    car IGN --> Diode ---> Switch (for manual shutdown) --> Relay control on.
    car ACC --> Diode ---> Join with switch wire above.
    On my car, the ACC line cut off during cranking. The above wiring keep the computer running when the key in either ACC or IGN possition and during cranking.
    BTW I use inverter and the relay is to control the inverter switch.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    May 2003
    MA
    I'm not using the Opus, but I connected the ignition wire to my car stereo remote line for the amp. So I can turn on the computer by turning the stereo on/off (I also added a inline rocker switch for when I want the stereo on but not the computer). In VW you can turn on the stereo without having the ignition turned onů.
    Apr 2003
    Just connect the Opus's Ignition wire to constant 12V via a separate switch.
    Oct 2003
    PORTO
    Quote Originally Posted by shchua
    Can i connect it to the 12v line of my headunit?
    So that when i turn the headunit on and off , the "CARPUTER" will also start and shutdown...could this work??
    Thanks for the replies
    Maximum Bitrate owenjh's Avatar
    Nov 2003
    NC
    Quote Originally Posted by VWTronics
    This is what he just said, use the stereo line, yes you will be able to do that.
    CarComputer Status: New Car & Broken (Motherboard Fried)
    Owen JH | My Linux Blog | The Tech Fellows
  1. Replies: 1
    Last Post: 12-31-2003, 01:30 PM
  2. OPUS 150 watt, USB stays powered???
    By GScherler in forum Power Supplies
    Last Post: 12-19-2003, 03:44 PM
  3. ignition wire for opus psu
    By liquid_smoke in forum Power Supplies
    Last Post: 09-09-2003, 11:58 PM
  4. Can the Opus be powered by an adapter?
    By orangewhip in forum Power Supplies
    Last Post: 09-09-2003, 02:52 PM
  5. Replies: 3
    Last Post: 05-28-2003, 10:45 AM
