Results 1 to 10 of 10
Thread: Accessory Line Delay circuit - Any ideas?
    Newbie MiniRX7's Avatar
    Aug 2003
    Toronto
    Hi guys, i ditched the car computer idea and went with an X=BOX instead.
    Right now i am using a DCtoAC invertor to power my xbox and everytime i start my car my x-box dies.
    Here is the plan. I am going to run the invertor directly to my batter instead of the cigerette lighter.
    I want to use a relay to switch the invertor on and off. HOwever on my car, when you turn the car to the crank position, it kills the 12 VOLT accessory line output.
    What i need is some typw of circuit that will supply the relay with 12volt during the period when i turn engine on (crank) until the car starts sot hat the accessory line then continues to power the relay.
    Any ideas?
    2k3 Max SE 6spd
    Temp setup:
    7" indash screen/Xbox running XBMC
    Carputer coming soon
    My 2003 Maxima
    Low Bitrate TheSpecialist's Avatar
    Jan 2004
    NJ
    Install a diode (1n4001) inline with your supply power with the positive side toward the incoming postive voltage. Then add a recharable battery in parralell on the negative side of the diode (opposite the incoming voltage). The diode will allow the car to recharge the battery wile the battery will hold you at 12vdc, during the cranking process. I have a garage full of 1000mAh NiCad batteries I am going to put on Ebay that will do the trick once I figure out the shipping. Circuit City car audio dept. also sells batteries just for this purpose.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by MiniRX7
    You can use this method.
    Car ACC wire --> Diode --> relay switch to inverter.
    Car IGN wire --> Diode --> join with the relay wire above.
    The reason is when the key at crank position, the ACC wire is cut off but the IGN wire is still hot so the relay wire get power from there. The diodes are there to stop power from mixing up your car electrical system.
    That is how I wire the relay that turn on the Inverter in my car.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Aug 2003
    Toronto
    Interesting ideas.
    To the first idea with batteries, i was trying to avoid using any batteries in the circuit.
    To the 2nd idea. Its a nice idea but i think there may be a delay between the switch over from ACC to IGNITION lines..and that may cause the relay to unlatch.
    Is there any type of capacitor that can codl the 12 volts for about 5 seconds at a minimum?
    Like running a diode to teh cap and cap to the relay swith? is that enough to keep the relay on?
    ED
    2k3 Max SE 6spd
    Temp setup:
    My 2003 Maxima
    Sep 2003
    Beach City, Socal
    The ACC line always has power except when the key is in the CRANK position.
    I don't think the ACC line is cut off during the switch from ACC to IGN. To find out, does your radio turn off while switch from ACC to IGN? Because most radio is turn on when the key is in ACC pos.
    The IGN always has power when the key is in IGN, during and while in START/CRANK pos.
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Thy should overlap....
    POS1 ACC
    POS2 ACC & IGN
    POS3 IGN & CRANK
    Acc is live in pos1 & pos2
    Ign is live in pos2 and during cranking, so a feed from both will cover all positions.
    Matrix, what sort of diode do you need for this?
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by Laidback
    I don't remember what it is (IN5819 or IN4004) but it a small one. A relay doesn't draw that much current that is why I use a small one. But bigger is always better (IN5822).
    Aug 2003
    Toronto
    Actually your right, the ignition is always live...
    But will the momentary switch over from accessory to ignition kill the invertor?
    Its the crank position that i am worried about, because the crank position is when the accessory gets killed meaning bye bye x-box and invertor.
    So my real question is, i connect the diode to the accessory line and the ingition line.. Feed both to the trigger on the real, and one or the other will continually feed the invertor? Hmmm sounds like it will most definitely work for sure. ONce i turn the key to POS 2, ignition takes over, and in crank it will continually give ignition. and as the car is running, the ignition will stay on keeping the relay alive and switch back over to accessory..
    WOW.. thats the best idea, and I most definitely think it will work.. And that even solves my other problem. I am connecting my xbox power switch to my remote starter alarm. So that i can turn the xbox on for wireless FTP transfers remotely. As teh car starts, then the invertor is on since ignition is power.. Then i hit the channel three to pulse the X-BOX power switch and voila.. all is turned on..
    Awesome.
    2k3 Max SE 6spd
    Temp setup:
    My 2003 Maxima
    Variable Bitrate NJay's Avatar
    Mar 2003
    UK
    I don't know if this is true for all cars but on my 2001 Celica
    Key in:
    Off = No radio
    ACC = Radio switches on
    Ign = Radio continues to play with no interruption
    Crank = Radio switches off and then back on when key release back to Ign.
    Does that match up with earlier??? I think it does as it implies the headunit is connected only to ACC live feed and hence due to overlap continues to play when I move the key to IGN. It then cuts off when cranked.
    This also explains when I remote start the engine or have it idling with the key out why my headunit doesn't come on. The Clifford installers were supposed to tie BOTH into the remote start system and obviously have only done the IGN line.
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by NJay
    Key in:
    Off = No radio
    - All Toyota Cars Ignition key switch work the same (at least here in the states). Your Celica's switch work exactly like all Toyota over here.
    - HU is connect to the ACC line that is why during crank, the radio shut off.
    On Viper Remote start system (one I install in the Supra), there are wires for Starter, ACC, and 2 IGN. The installer must of be lazy not to connect the ACC line to your car ACC or the Remote start system doesn't have the ACC line.
    When I need to do config the carpc or transfer short file or anything can be done in 15 min. I just remote start the car -> start the carPC and VNC on my desktop to the car PC. After I finish the task, shutdown the PC via VNC and a minute later, shutdown the car via alarm remote. I don't have to see or walk to the car for the whole process.
  1. Easiest way to tap a 12V accessory line
    By fluffy2097 in forum Newbie
    Last Post: 08-08-2004, 02:20 AM
  2. help with delay circuit
    By albysure in forum Off Topic
    Last Post: 05-30-2002, 09:53 AM
  3. delay circuit
    By jshrieve in forum Power Supplies
    Last Post: 04-18-2002, 11:38 AM
  4. Anyone haveing probs with the relay delay circuit
    By Synx in forum Power Supplies
    Last Post: 10-01-2001, 05:15 PM
  5. some accessory ideas
    By moossmp3 in forum General Hardware Discussion
    Last Post: 09-08-2000, 06:27 PM
