with a dc-dc solution you would ditch your existing power supply and get a DC-DC power supply.
the 12v and ground from the car connect to the DC power supply, and that plugs into the mobo and your devices.
search for the opus supply ... it's more expensive but will be a better solution to provide power to your p3 ... it's also easier to hook up i think.
the pw-70a from mini-box also gives enough power, but you need to regulate the voltage and that becomes a problem.
LinkBack URL
About LinkBacks
