So, since you are such a fanatic, what did you do to try and solve the noise problem? Noise is simply some sort of ground loop, which may be due to a poor
wiring job, insufficient grounds, a noisy ground location, a bad connection, etc. Did you trace the noise down and see how the ground loop was forming, or did you try changing ground locations, larger gauge wire, and grounding the PC case? Did you try a ground loop isolator or an ac isolation transformer? You mentioned skipping the nosie filters, but you don't need them if you stop the ground loop.
Were you attempting to use your
head unit along with the PC and inverter? If so, the ground on your head unit probably had a lot to do with all the extra noise. I threw away my head unit when I installed the PC; all my speakers are powered from external amplifiers, so I didn't need it, and there aren't any decent DJs on
radio anyway, and I can't stand commercials or talk radio, so I didn't want it
Just so others aren't mislead, inverter are not _just_ designed for portable tvs.
Well, I was asking for YOUR reasons, not everyone elses. That way it doesn't look like just another flame. Thanks for giving them.
AMD XP 3000+
512MB DDR
12.1" LCD
iGesture mini keyboard/touchpad
USB GPS
D-Link USB 802.11g 108Mbps
300watt ATX psu
SB Live
sound
CDRW
DVD
Coleman 800watt RMS inverter
Our Pro
Power Controller, v2.4
tank ez v1.0
I have more flexibility than you likely just because of our Power Controller. Have you looked at our Power Controllers? They offer so many features you cannot duplicate with an Opus. What is your CPU? If your running a setup like mine on Opus, you either underclocked it, have 2 Opus' running in
parallel, or are killing your Opus and may have a PC that locks up due to under-powering issues. And I can add much more to my CarPC without worrying about power problems. I can also power nearly anything off the inverter I want. It has so much extra power available I can run a 2nd PC and still have extra power (If I decided to do a dual carpc install) The only thing I don't have is as much run time with the car off - but for me, that isn't an issue as I rarely use the PC when the car isn't running. And just so you know, I never had noise problems; not even the first day I installed the inverter. But I used 4 gauge wire and ground locations I knew were not noisy.
Here is the post, I just restated what he said.
Opus 150W - 1 week later impressions and questions
KyferEz
