Page 6 of 6 FirstFirst 123456
Results 51 to 57 of 57
Thread: opus vs inverter
  1. #51
    Variable Bitrate BMVEE's Avatar
    Mar 2005
    Beautiful British Columbia, CANADA.... eh!
    Simple question... though I'd ask.... I am running my system (Athlon 2000+/GPS/BT/Audigy2/Wireless) using inverter and I do have noise. Strangely, I can hear it at the pc, which means I likely have an inverter with a noisy AC circuit. Are there any recommendations for filtration. I am running directly connected to the battery with 4/0 guage wire about 2' long (Gotta love BMW battery in the trunk). I have grounded the PC chassis to the common ground bond point to minimize potential difference. The latter did serve to minimize the noise, but it is still noticable (I would like to eliminate). I am going to try running an different amplifier, (I have a spare), but I don't expect I'll have much luck there. Filtering DC is a snap, but I've never given much thought to filtering AC from an inverter.
    Thanks in advance!
  2. #52
    Mar 2005
    kansas
    Well lets see here if i can stir things up a little...LOL Anyways why we argue this point is beyond me. An opus is like $200 and last i looked the inverter and power controler on the carpcstore site is like $125. Add the cost of a PSU if you dont have one and viola youre over $200. (And if you tell me you can get a good switchable PSU for $75 please slap yourself so i dont have to come do it for you.)
    Now as i see it anyone planning on building a powerful PC wont mind the extra cost of controler, PSU, and inverter. But those looking at the epia type boards or something similar (micro atx) would be better off with the OPUS.
    And anyone seriously interested in this hobby would be better off with a sproggy or mastero DIY. If nothing else for the learning experience. (You will need it later as your imagination and confidence kick in).
    Over powering either inverter, OPUS, or any other solution will eventually kill it. And i may have missed something but what happened to the Keypower in this discussion or the Aries? They would both work great with a powercontroler that kyle has mentioned. But then again you are over $200 bucks in combined expense.
    So as i see it anyone trying to find a cheap solution for powering a carPC needs to think twice. Cheap out on something esle like the 3rd or 4th useless never used monitor and spend some cheese on your power setup. All that fancy **** dont mean a thing if it fries or freezes up and crashes.
    EDIT > Forget to mention someting. I am strongly in support of flaming and buring on this forum.
  3. #53
    Variable Bitrate lastberserker's Avatar
    Apr 2005
    Seattle
    Quote Originally Posted by sansoo24
    (Hello? I've got this one for testing my setup: +3.3V@17A, +5V@12A, -5V@0.3A, +12V@13A, -12V@0.3A, +5VSB@2A = $22 + $.99 s/h. Nice AC-DC PSU - cold, no noise, no hiccups (and what's the heck is VSB? ))
    Asus K8S-MX ~ Athlon 64 2800+ ~ Kingmax MPXD42D-2K 1Gb ~ Seagate ST960822A 60Gb ~ PSK-3100 PS/2 kbd ~ MR-350 GPS ~ Hawking HSB1AP ~ Buffalo WLI-USB-G54 ~ 8" Dynamix TS LCD ~ DSATX ~ XCard ~ TVedia ~ some LCD TV ~ Vista ~ MapPoint 2006 ~ iGuidance 2.*
  4. #54
    Mar 2005
    kansas
    Its still only 200 watts though. If youre gonna put a high powered machine in that can play doom3 and run a dvd at the same time youre prolly gonna get something bigger and by a more reputable company like antec. I personally have never seen a true power antec for $75. At least not from any place i would trust giving my money too. But i could be wrong so someone enlighten me
  5. #55
    May 2005
    http://www.enuinc.com/
    Assortment of Entec PS and cases. Been buying stuff from them for close to ten years.
  6. #56
    Apr 2005
    Charleston, SC
    i got a $35 450w psu (from newegg) powering my home computer, and it works great. athlon 3000, 2gb ram, 2 hd's, 2 cd/dvd drives, 3 pci cards, 1 agp, 6 fans, blah blah blah.
    also, i wanna say most of the people here had at least one valid point. basically, opus works better for some people, inverters work better for others. i personally believe an inverter is the best overall option if wired/grounded well, especially if you want to power other accessories, but several people have had good experiences with opus.
  7. #57
    Maximum Bitrate Chita79's Avatar
    Oct 2004
    San Diego, CA
    i felt like reviving this thread a bit...
    an inverter is the way to go for an xbox in the car
    but you have to make sure you use a PURE SINE WAVE inverter which costs at a minimum $150 for 300W continuous. You wont see any of the negative aspects of inverters if you get a pure sine kind.
    that is all!
    thanks
    '05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
  1. relay, inverter, fuse problems
    By cheesyhoward in forum Power Supplies
    Last Post: 06-02-2005, 09:04 AM
  2. relay, inverter, fuse problems
    By cheesyhoward in forum General Hardware Discussion
    Last Post: 06-22-2004, 03:05 PM
  3. opus and inverter quick q
    By sweetrobot2k in forum Power Supplies
    Last Post: 10-16-2003, 12:03 PM
  4. Opus dc-dc and inverter...
    Last Post: 09-19-2003, 02:00 PM
  5. odd inverter behavior
    By jshrieve in forum General Hardware Discussion
    Last Post: 04-10-2001, 04:53 AM
