Page 1 of 28 1234567891011 ... LastLast
Results 1 to 10 of 272
Thread: Mastero Mk-3.5 & Mk-3.6
    FLAC Mastero's Avatar
    Aug 2001
    India
    Mastero Mk-3.5 is here..!
    Hello Friends,
    The Mk-3.5 is here.
    Mk-3.5 uses max chips (787cck & 788cck) TO-220 package orLinear chips (LT1074CT) TO-220 package with resistors.
    Input 8~40
    Output as the Mk3.0 but the +12v uses Lm2587T-12 in boost mode with internal switching of 5 amps max.
    Flaw found and rectified. MK-3.6 does not exist. Download the below file for further information
    This PSU fits perfectly in a normal ATX psu case.
    Tested the PSU works great Booted a Fv24 , WD 40gig & a CDrom no problem
    Things to come:
    The kit version of MK-3.5 shall have everything but the following
    MAX766, MAX787, MAX788 , Lm2587T-12
    Everything includes Heatsink and the Inductors also,
    MK-3.5
    Pcb Layout
    IMPORTANT ISOLATE ALL THE IC ON THE HEATSINK
    Cheers
    Mastero
    Maximum Bitrate none's Avatar
    Sep 2003
    Edit: nevermind, I see now that you mean Linear as a company, not a regulator type. They are still switching regs.
    Doesn't the LM 2587T-12 require a transformer (T6) to work properly?
    Aug 2001
    India
    Quote Originally Posted by none
    The LM2587T-12 requires a transformer in the flyback mode but i am using it in the Boost mode... with internal 5amp switching capability...
    Vote:~ Onboard fuse holder ??
    Cheers
    Mastero
    Sep 2003
    Quote Originally Posted by Mastero
    Cheers
    Mastero
    I'd say yes to the fuse holder.
    I'm curious why you have chosen to go with the boost method rather than the flyback. At first glance I thought it might provide a lower component count, but then I realized that you need to build a whole extra 5v rail to provide the input to it. Isn't the flyback method more efficient?
    I think you could get away with one PCB for both versions, just swap some resistors for jumpers.
    Great work!
    Aug 2001
    India
    Great work!
    The flyback method gets us again to the Transformer thing hard to get etc..... so the boost method is simple and good ...
    The 5v rail is at 10 amps so better for the Mobo and other stuff the 12v rail is not going to use 5 amps 24/7 so there shall be more juice at the 5v rail which is a good side ...
    As for the one pcb .. hmm i guess the jumper thing can work .. i shall give it a taught...
    Cheers
    Mastero
    Jan 2004
    Kentucky
    What are the Maxim Chips package type? and how many of each are needed?
    When will you have kits available?
    Aug 2001
    India
    Quote Originally Posted by Twizted
    Read above for the package.
    Kits shall be out soon.
    Cheer
    Mastero
    Jan 2004
    Kentucky
    Do you know around the price range for this?
    Also I am thinking I will use this (if I can get it) in unison with the Opus 150 by useing the opus to power my Motherboard and HDD and using the MK 3.5 to power the other devices such as DVD-rom, monitor, fans ect... is this possible to have the MK 3.5 turn on with proper timing boot extra HDD's and DVD-rom and not cause flaws?
    Aug 2001
    India
    Yes you can but might meed some modification.
    Mastero
    Aug 2001
    India
