Results 1 to 10 of 16
Thread: Opus Powering Xenarc
    Sep 2003
    Hi
    Can someone please post detailed instructions on how to power a xenarc touchscreen from an opus power supply???
    Low Bitrate telstargb's Avatar
    Aug 2003
    Leicester, UK
    Quote Originally Posted by imi1232000
    Hi
    The easiest way would be to extend one of the hard drive power connectors and grab the 12v from there (yellow wire)
    Mondeo 1.8 Zetec : Epia 800 : 60gb drive : Lilliput 7" VGA : Sapphire USB GPS : Opus 90w : WinXP : Road Runer : Destinator
    Feb 2004
    Can you power the xenarc with the yellow wire from the radio harness ( nothing else would be getting power from that wire, just the screen)
    thanks
    Aug 2003
    Leicester, UK
    Quote Originally Posted by dsbenjamin
    thanks
    Depends what the V is. I would personally feel safer powering it from the yellow wire from the PC
    Variable Bitrate fly_dutchie's Avatar
    Feb 2004
    Amsterdam
    Hi
    This is what Kris from Opus mailed me:
    "You can use the drive power connecter +12V to power the LCD. provided if you have enough reserve power.
    Kris"
    dutch
    "It does not understand, if it does not ride."
    M10000, 512 Mb, 2,5" 40G, Slim DVD, Opus 90W, Xenarc 7", Leadtek 9532 GPS,
    RoadRunner, MapMonkey, Pioneer HU, Pioneer 4 ch 400W, Kappa 6.5, Basslink X 200W
    Dec 2003
    another powering question- concerns that
    Quote Originally Posted by telstargb
    Say i have also a screen not xenarc though , now i got a positive and negative for power from it, should i just "Y" connect them to the yellow 12volt? or do i connect the positive to the yellow and the GND from the opus with the negative from the screen?
    thanks
    Feb 2004
    Amsterdam
    Take the yellow +12V from an unused drive power connector and connect that to the positive of your screen.
    Use a black negative from the same drive power connector and connect that to the negative.
    D.
    Feb 2004
    But I wouldnt have to "Y" connect it, I'm installing with now headunit. Will there be enough reserve power to power the xenarc?
    Sep 2003
    I think you are confused. The yellow wire going to your radio is not regulated and should NOT be used for screen power. You will have to Y a drive power cable from the PC and extend it to the screen. this will supply 12v regulated power to the screen
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    I got a cigarette lighter adaptor with my xenarc so I would assume it would work fine just hardwired into the power for the cigarette lighter. Why do you want to connect it after the OPUS and not directly to the car's power?
    Hi
  1. WTB: Opus 90W psu, dvd, 7" xenarc
    By pottillo in forum Classified Archive
    Last Post: 02-03-2004, 10:57 AM
  2. Wanted: Opus, Xenarc, USB GPS
    By kovan in forum Classified Archive
    Last Post: 01-27-2004, 02:31 PM
  3. Hooking Xenarc LCD to opus?
    By XxAndyxX in forum Power Supplies
    Last Post: 01-20-2004, 11:33 AM
  4. Powering Opus 150w Indoors
    By replicant in forum Power Supplies
    Last Post: 12-20-2003, 09:35 AM
  5. Powering Xenarc from an Opus?
    By Lytheum in forum Power Supplies
    Last Post: 03-22-2003, 07:50 PM
