Results 1 to 8 of 8
Thread: OPUS install in an ASUS pundit
    Variable Bitrate craigyb's Avatar
    Sep 2003
    UK, Sale, Cheshire
    here's some pics of the OPUS 150W PSU in an ASUS Pundit PC.
    it's a 2.4ghz celery with 512mb ram and 160GB disk. Also I've added a wifi card, 2 more USB ports, +5v and +12v sockets.
    Audi S8 supercar
    Modded Xbox 400GB HD
    Rear 7" screen & navplus
    Toyota Hiace Van
    Shuttle PIII 866 256Mb 10GB OPUS powered
    MediaCar & Mappoint 2004
    Custom fit 7" TFT VGA TSK
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    That's pretty sweet.
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
    Sep 2003
    UK, Sale, Cheshire
    Well OPUS in aan ASUS as a no go. The PC was very erratic, it powered up but would not boot. The one time it did boot it was fine, then it wouldn't boot again.
    Maybe 150W isn't enough for the ASUS, so I my have an OPUS for sale in the UK very soon.
    Craig
    Audi S8 supercar
    Toyota Hiace Van
    Mar 2004
    Craig,
    Ever get this working? I have a Pundit and i'm about to buy the opus. Thanks
    Asus Pundit Barebones PC
    7" Lilliput LCD
    P4 2.8ghz 512mb 120gb
    Windows XP Pro, VOICES
    Sony Xplode 10in Sub, Rockford 600w amp
    Pioneer 6x9's and 4x6's, Kenwood 4ch amp
    Black Widow Alarm with Pager
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    I would think it requires alot more than 150 watts to boot up that motherboard and cpu combo along with all your peripherals.
    That celeron is based on the P4 right? The new P4's eat watts.
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
    Mar 2004
    If the opus is efficient i can't see there being a problem.
    7" Lilliput LCD
    Jan 2002
    Long Island, NY
    The Opus can be as efficient as it wants.
    But if the system requires more than 150 watts and the Opus can't supply it, the system will not boot or be stable.
    Mar 2004
    Heres how psu's work:
    You can have an inefficient 300w power supply that can't push a steady voltage to the motherboard and its components. And you can have an efficient 150w psu that can power all the devices no problem.
    When the manufacturers rate their devices, some rate rms, some rate peak. Most cheap brands are peak, therefore an efficient 150w psu can power just as much as an inefficient 300w (as an example) psu.
    7" Lilliput LCD
  1. EPIA-M and Opus not booting up...
    By Huge in forum General Hardware Discussion
    Last Post: 09-07-2004, 01:01 AM
  2. One reason not to buy the Opus
    By orangewhip in forum Power Supplies
    Last Post: 03-13-2004, 04:15 AM
  3. New OPUS 150w not working?
    By kylechughes in forum Power Supplies
    Last Post: 01-27-2004, 02:21 AM
  4. Opus Power Limits
    By mhermann in forum Power Supplies
    Last Post: 05-23-2003, 06:06 PM
  5. Where does ground loop isolator install?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 09-14-2000, 08:10 AM
