A fuse in the + wire is essential. Imagine what would happen if you short that wire to ground and your battery tries to put 800 amps through it! Very hot wire before it burns out; melted, possibly burning insulation; maybe burn your car up - not what you want to happen. Some put fuses in the - wire as well. Check the Opus specs on their web page for the answer to the voltage question.
LinkBack URL
About LinkBacks
So 12 will be fine, but run nice thick gauge to the rear fused distro so you can add a 1000 watt sub etc...
