Results 1 to 2 of 2
Thread: OPUS isn't working!?!
    Maximum Bitrate XxAndyxX's Avatar
    Dec 2003
    Edmond, Oklahoma
    I hooked my opus up and there seems to be a problem. Whenever I start my car the opus doesn't turn on(I have to jump it on with a screw driver) then when I turn my car off the opus doesn't turn off. Has anyone had this problem or knows what's going on? The acc. wire I'm using works fine. When I test it with a volt-meter I get 13.8 when the car's on and it turns off when the cars off. It has a firm connection with the opus wire.
    Apr 2003
    Did you connect the power switch cable from the Opus to the motherboard's power on header ? I couldn't get the Opus to power on (the green LED flashes twice) unless this cable is connected properly - it's polarity-sensitive so if it doesn't work, just turn it around.
  1. Replies: 109
    Last Post: 05-31-2004, 09:07 PM
  2. One reason not to buy the Opus
    By orangewhip in forum Power Supplies
    Last Post: 03-13-2004, 04:15 AM
  3. New OPUS 150w not working?
    By kylechughes in forum Power Supplies
    Last Post: 01-27-2004, 02:21 AM
  4. Opus ITX Vehicle Workstation
    By Cirrus in forum General Hardware Discussion
    Last Post: 09-09-2003, 03:08 PM
  5. Opus Power Limits
    By mhermann in forum Power Supplies
    Last Post: 05-23-2003, 06:06 PM
