Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: boost-buck 12v regulation for a PW-70a
    Dec 2003
    Hey there.. i've got a few questions about switching regulators for all you power nuts out there.
    i'm using one of those retarded power supplies that doesn't regulate the 12v line and i'd like my carputer to be able to a) survive a crank and b) run off the alternator
    what i'm looking for is a high-current (5.8a or more) boost-buck 12v regulator that has an input voltage range wide enough to accomodate the cranking drop and the alternator voltage, something like 6v-15v.. it only needs to be able to boost while cranking, the rest of the time it's going to be bucking from the alternator or just leaving the battery power alone. if anyone knows what i could do here i'd love to hear about it
    Maximum Bitrate none's Avatar
    Sep 2003
    My suggestion would be several TI PT5071's. These are only 1.5 amps, so you will need three or four, but it will still probably be the best solution. Search around here, several people are using these chips.
    Dec 2003
    okay, those look nice for regulating 1.5a but is it possible to link them together to increase the power output? i was thinking something more along the lines of a chip to drive a pair of mosfets like the max1858 (from maxim).. the problem with that chip is that it's only a buck controller so it won't let me survive cranking, but the power handling is right on the money.
    Sep 2003
    Quote Originally Posted by greenwire
    Yes.
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    if you run the chips parallel to eachother you can use a larger current
    Dec 2003
    right on.. does anyone have any schematics for that or is it just a simple matter of hooking the outputs of a couple chips together in paralell?
    Dec 2003
    eh, just wanted to refresh my question about the schematics.. i'm just wondering about the filter caps on the input and output and whether or not it's possible to run all 4 chips with only 2 capacitors or if the paralell arrangement needs all 8 caps to ground.. also, what should pin 2 (UVadj) be connected to? i can't find that anywhere in the datasheet... one last question.. what about pin 3 (stby)? what's that mosfet doing there and do i need it?
    (here's a link to the datasheet http://focus.ti.com/lit/ds/symlink/pt5071.pdf )
    Jun 2003
    Chicago
    I am using 4 PT5071's in parallel to supply my PW60. You'll need to isolate the outputs via schottkey diodes...it works very reliably.
    Jun 2003
    Chicago
    Quote Originally Posted by EBJUSTIN
    Here is a quick and dirty schematic. You can leave pins 1,2,3 & 14 unconnected.
    Nov 2003
    Apeldoorn, Netherlands
    schema for 3x pt5071 (want a 4th: not difficult, just add one, simple schema)
    the diodes you need: 1n5401
    I used 100uf 63v capicitors
    This is mine:
    Newbee, sorry for my bad english. lol
    Trying to built a carmp3 systeem
    own psu: max788, pt5071, pt5024
  1. Has anyone built a boost - buck circuit?
    By starfox in forum Power Supplies
    Last Post: 01-22-2004, 07:16 PM
