Results 1 to 6 of 6
Thread: NE1 seen this Pure Sine Wave inverters?
    Variable Bitrate dbinnc's Avatar
    Sep 2001
    Greensboro, NC
    http://www.donrowe.com/inverters/puresine_300.html
    Wonder if they are that much better and worth it?
    Oct 2003
    Nice.... but the price is so high on it, I don't know.... too bad we couldn't incorporate something like this w/ the OPUS.... that would be worth $200 - $250.00 dollars for the whole raw deal!!!
    New CarPC on the way again I think. I miss my old one!!!
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    For inverters, Pure Sine Wave is the best. However, if you're powering a PC, then you still don't want to go from DC-AC-DC. The Opus is still probably the best thing to do.
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Maximum Bitrate owenjh's Avatar
    Nov 2003
    NC
    I think with pure sine wave you can power a UPS, if so its shutdown controller could do everything for you just have it connected to the ACC
    CarComputer Status: New Car & Broken (Motherboard Fried)
    Owen JH | My Linux Blog | The Tech Fellows
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by owenjh
    That's good idea.
    You can have the UPS software shutdown the computer when AC is removed after xx minutes but then how would you turn the UPS on and off?
    I think SDC is still needed.
    With the price of a pure sine wave inverter and UPS and installation size, OPUS is much better but it only 150W. dammm.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Feb 2003
    SE Ohio
    Quote Originally Posted by MatrixPC
    That's good idea.
    My point exactly. the Opus costs nearly 200 dollars, and ONLY puts out 150W DC. That's why I opted to go with an additional 65AMP alternator for the computer (replacing the AC Compressor), a 300W (rms) Inverter (to 120vac) and then a 450W/700va (volt-amp) APC UPS (APC model SU700-NET, pure sine-wave output, over/under-voltage correction, Power Chute etc). Only problem I have right now is the UPS won't power up in car even when fully charged. I think it has something to do with the "Site Wiring Fault" protection that it has built into it. The "Site Wiring Fault" light comes on, so I think I need to make sure that:
    • All Cases Commonly Grounded (DC->AC Inverter), UPS, & carPC
    • Negative Prong on 120vac is Connected to Common Ground (Car Frame)
    If you're not paranoid, then you're not paying enough attention. -kmfdmk.com
    http://www.mymp3car.com/MP3Car/PSUpower.asp
    1985 Supra 7M-GTE
    10.4" Planar LCD
    ECS GOAL3+ mobo w/ 512mb + 8GB sdhc
    Edimax EW7318USG Wifi w/ 7 db Ant.
    USB GPS
  1. FS : 3D Render Card - ART VPS - PURE P1800 PCI
    By ccsnet in forum Classified Archive
    Last Post: 03-09-2004, 09:36 AM
  2. Pure sine wave inverters. worth it?
    By nzKAOSnz in forum Power Supplies
    Last Post: 10-27-2003, 04:48 AM
  3. Different invertor - Via Epia M
    By mag2 in forum Power Supplies
    Last Post: 06-11-2003, 08:15 PM
  4. Replies: 11
    Last Post: 01-13-2003, 03:55 AM
  5. sine vs. modified sine wave inverters
    By spitzfan in forum General Hardware Discussion
    Last Post: 01-05-2000, 10:59 PM
